Controller is confusedA power
surge or random non-reproducible action of the universe may have
resulted in the controller's program ending up in an infinite loop. Pull
the plug for a minute or two to reset it.
KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
If the problem persist, the main control board is faulty. God bless you
Hi, Place you cup of water in the microwave with the tea bag in the cup....The run the microwave for 30 - 1 min. just like you were heating the water...
all microwaves have flame sensors that will cut the power in case of fire, this sensor will most likely have to be replaced. this will require you to drop the m/w and remove the case.
Hi. this code represents a key pad or control board malfunction. you will have to make sure the key pad or control panel connectors are connected tightly and securely. If the wires and connectors are secure, the actual control board may be faulty and you will need to replace it at this point.
Your owner's manual (see link below) suggests unplugging it for a few minutes then trying again.
F6 is usually a problem in the controller / circuit board.
If it still has the error message, it needs to be serviced.
To find the Amana authorized servicer in your area, contact your local distributor or contact the Amana ComServ Support Center at 866-426-2621 or [email protected].
Owner's Manual: http://edge.maytag.com/AmanaCommercial/12695301.pdf
I appreciate your rating of this answer. Good luck!
