Change the water control valve because it is not shutting off once the ice maker is full. The valve is sticking open slightly once power is off to water valve. What is the model number of your Kenmore Elite Model numbers for Kenmore most times look like this example=> 321.456789
Sea Breeze
Kenmore Model Numbers
Do you have to remove door to change out this part? Upright freezer part number 216979600
I found the answer to my question on another website so I am posting my own solution. To change out the electronic control which was a very simple thing to do...(don't pay a service person to do it and charge you extra), with a sharp knife very carefully peel back the inner label (like a sticker) of the display just on the ends to expose the screws. When the screws are removed the plastic housing will come off. Unplug the wire, change out the board by removing 3 tiny screws, plug it back in and put back the large screws. TA-da! And it even fixed my problem which was "freezer working, but alarm going off, and temperature uncontrollable, couldn't change to above -12 without it turning off freezer."
