How to clean filter
The de-humidifier is a niche product. Its only job is to remove
moisture from air to alleviate the problems of mould and mildew. It is
very similar in operation to a window air conditioner.
A dehumidifier though will add heat to the room, while an air conditioner will remove heat.
The de-humidifier is an appliance that requires regular maintenance.
This may be because it’s icing up, overflowing, not removing enough
moisture, or simply time for a good cleaning to maintain its
efficiency. If you don’t feel handy enough to attempt this project
contact your appliance repairperson.
The following is a step-by-step method used to return your de-humidifiers to its peak efficiency.
Tools required
1 Multi pocket container (old ice cube tray)
2 Long handled brush
3 Oil can
4 Rags
5 De-greaser or spray detergent
6 Selection of screwdrivers
7 New filter
1… Remove water collection bucket and put aside.
2… Remove the filter from rear of machine. Filer is usually within a
frame and simply pops out. If no filter proceed to next step. If it is
a disposable filter simply replace it with a new one. Other types are
made in a plastic frame and can be cleaned and reused. To clean a
filter lay it flat in the sink and sprinkle surface with powder laundry
detergent. Plug sink drain and turn on hot water. Cover filter with
enough water to submerge. Soak for 15 minutes. Remove from water and
rinse. Hang up to dry while proceeding to next step.
3… Remove the rear grille from the main body of de-humidifier. If none
proceed to next step. If there is resistance then look for hidden
screws. If grille locks into cover proceed to next step. Once removed
place the grille aside until later.
Tip: Dehumidifier may use different types and sizes of screws. Use ice cube tray to segregate.
4… Remove metal cover of de-humidifier to access inner workings. Cover
screws may be difficult to see because are often painted to match body
color. Usually two or three screws along each side of base. Once screws
are removed lift the cover straight up. Use extreme caution at this
point. Front grille may be secured to cover. Some fronts are put
together like a puzzle. Parts often interconnect or are screwed to one
another. If front grille lifts off with cover try to separate before
proceeding. Front grille may lock into groove along front edge of
cover. Avoid pulling off any wires from humidistat or indicator light.
5… When cover removed this will expose the heating and cooling coil.
They may appear as one but are actually two separate coils in very
close proximity. Both will need to be cleaned.
Use a narrow brush to remove surface dust and dirt from the front and
rear surfaces of coils. Use an up and down motion to avoid bending
fins. Area between two coils must also be cleaned. Use caution, the
fins are soft aluminum and can be easily damaged. Once surface dirt is
removed, spray with de-greaser or light cleaner. There is a good
product on the market called HVAC cleaner. As the name implies it is
meant for Heating, Ventilation, and Air Conditioner coil cleaning. If
this is not available Fantastic Spray cleaner used in kitchens and
bathrooms works quite well. Remove dirt and excess cleaner by slowly
pouring warm water into fins. Do not allow the water to enter any
electrical connections or components. As an added precaution cover the
motor with one of the cloth rags to protect it from the water.
6… With cover, rear grille, and front grilles removed locate fan motor
for oil holes. Add a few drops of oil to each end of the motor body.
Use a general purpose (3in1) oil or clean motor oil. A #30 oil is
sufficient. Three or four drops on both ends of the motor body are
sufficient. Add the oil slowly, pausing a few seconds between each
drop. If added too quickly over-lubrication will result.
7… Straighten any bent fins. Use a fin comb if available. If no fin
comb then use something soft such as a Popsicle stick. Straightening
the fins will increase the efficiency of the airflow through the coils.
Use caution as these coils are filled with high-pressure refrigerant.
8… Wipe any dirt from fan blade using a soft rag. Do not bend blades. This would cause a vibration that would harm the motor.
9… Vacuum all surfaces including front and back of grille assembly.
Vacuum underside of metal cover. Vacuum dirt buildup from base and any
other exposed surfaces.
10… Drain any water left in the base and allow it to dry.
11… When completely dry plug in and test operation. On some models
testing may require temporary override of bucket overflow switch. Test
that cooling coil begins to sweat water within few minutes of
operation. If everything appears okay unplug and reassemble. Insert
water collection bucket slowly to avoid damaging float switch mechanism.
