Download installer applications in your PC. Connect mobile phone to PC. Copy the file in your phone memory card. Plug off the phone from PC. Open folder where you save the file. Click file > Option > Install
Install software which you have got with your phone. Samsung phone accepts software viz. "Samsung PC Studio"... installed it... this will help you
Don't for get to install driver of your cell..
Hope this has helped you...
Please rate the answer.
Thank you...
just install pc suit in ur computer afterward u connect your phone to pc then surf the net for free install java softwares then download to pc, then download to phone
Are you able to install other programs on your Laptop or it's just an issue with the Samsung PC Studio?If it is then possibly it's a hardware or software problem in you laptop. FIrst of all if you are trying to install the program from the CD that is provided with the samsung mobile then do not use it. Uninstall the program from the laptop if you already installed it. Download the updated PC Studio from here Samsung PC Studio ...click on the Software tab and then Download against the PC Studio. Download and then install and make sure you do not connect the mobile to the PC before installing the full software. Good Luck.
run again your pc studio cd software installer.. by default, it will play and give the swf home page where there is an option for install usb driver. select install usb driver in order to install your usb driver but before installation disconnect your phone from pc and remove the usb cable. once it's installed, right click your PC studio and select open automatically when device is connected. >>on your phone, select settings,select settings for your pc connections, check ask for connections and reconnect your phone.
You need to use the CD that came with your mobile phone. First Instal the relative software from SAMSUNG's CD and then plag the USB connection and start using it.
If you dont have this CD search into Google for the said software or check SAMMSUNG's web site.
go to the link below for the software
http://uk.samsungmobile.com/wcms/support/softwaremanuals/softwaremanualinfo/index.jsp?phonemodel=SGH-D900&swType=SW
