SOURCE: Dyson Power Button Problems
Hi.
Sounds like the switch is faulty & will need replacing.
http://dysonmanuals.llc.nu/
Chris.,
SOURCE: Runs 10 - 20 seconds then quits-restarts on next trigger pull
Check battery maybe is old or not correctly charged.
SOURCE: I have the same problem as steve967 The dyson
Dear Michael_Stad,
I am going to sound like a broken record but here is my same answer to another person with the same problem.
I have I had the same problem with my Dyson DC16, where it only runs for a few
seconds at a time with each trigger pull. My husband called Dyson
(Canada) and without hassle they shipped us a replacement part which I
just received this morning. The replacement part sent to us is: DC16
Main Body with Rating Plate. It is also under warranty for 1 year. The
great customer service makes up for the flaw in the machine. Also,
Dyson is aware of the problem. Hope this helps.
SOURCE: Power shuts off on my dyson dc17 animal
I had the same issue. Got on the phone with Dyson. THe vacuum has a safety feature where if the motor gets too hot it cuts off. You have to leave it for 45 minutes or so and then it will work again. There is an underlying issue though. My problem was the black gasket thats in the debris bin shifted, probably from when emptying i pushed it on something. The black gasket should actually hang off the bottom like a skirt and the 2 groves should fit in on the groves of the gray mechanism. This seal is what provides 100% suction. Because of this..my vaccumm has been accumulating pet hair by the belt which i hear alot of people talking about and especially in the filter area. This is because I broke the seal by not having the gasket in place properly and it wasnt sucking 100%. They are sending me a complete new cyclone unit which has the debris catcher as well as she said its probably so caked up with debris it will never work again 100%. no questions asked they are sending it to me free of charge.
So if you remove the clear cyclinder debris catch thing all you will have is the purple cyclone on top and on the bottom is the black rubber gasket....
SOURCE: I have a dyson hand held that shuts off after just
yeap..... i just found a fix for this ,, its mad how easy it is to fix as well...and it works 100%,,,
now dyson implemented a filter magnetic switch if u take your filter off you will see a small magnet in the corner,, u will notice where the magnet is behind it is rased platic,, now,,that the problem on the main board the transistor that picks up magentic signal from the filter is dud,!
dont ask me why it happens,, its a pain i know.,.
now take off collection pot for dust now take battery off.
now where the serial number is theres 2 hex screws that need taking out..
now u will see a small pcb board.. remove with one tiny security screw holding it in,, once removed pull both red plug off thats the digital motor plug.. and white plug which is vcc..to battery,, once u have done this pull the board down and back gently. as there is a long bit of board that goes up the back of the dyson plastic be very carefull pull this out.. now the long and thin pcb board that is hidden is what we need there is a tiny transistor,,, we need to remove this carefully..once removed,, we solder a thin wire from 2 point A+C need to be soldered together with a thin piece of wire, it will not harm the motor.. as long as u keep it clean,,
these points corolate to the transistor,,
A
B C
SOLDER AND A+C WITH A FINE PIECE OF WIRE NOW,, AND WALLAH... fixed put it all back together again,,, charge the battery,, and your away,,, working again,, if not u have other faults.. but 99% fix this with flashing red led,,,!!
