If it is this one: http://www.bauhn.com.au/_literature_149691/ASBCS-815-S_-_Instruction_Manual Then you can charge it with a Usb to micro usb cable on your phone charger. You only have to buy a cable like: https://www.ebay.com/itm/UGREEN-Micro-USB-Cable-5V2A-Fast-Charger-USB-Data-Cable-For-Samsung-Android-HTC/152284131947?hash=item2374d7726b:m:mbr9-X9bM-Ys7kETXM2bsYg
Amazon.com, Inc.
Rating: 2.9 - 22 reviews
1A AC Wall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA .... If you try to use the tablet while it is being charged, no charging will take place.
Amazon.com, Inc.
Rating: 3.7 - 6 reviews
HQRP USB to micro USB Cable / USB Charging Cable for Hisense Sero 7 LT E270BSA / Hisense... ... HQRP Micro-USB AC Adapter rapidly charges your Cell Phone / Tablet PC ... This one does not. ... Yes No Sending feedback. ... $3.91. 1A ACWall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA Tablet.
Amazon.com, Inc.HQRP AC Adapter Dual microUSB Charging Cable for Hisense Sero 7 LT E270BSA... Do not wait until charging one of your devices to charge the second.
Mini USB:
http://www.ebay.com.au/itm/New-1m-USB-2-0-Male-A-to-B-Mini-5-Pin-Cable-Lead-XC03-/321443971464?pt=AU_CablesConnectors&hash=item4ad78dc188&_uhb=1
Yes you can charge your player through main. All you need is a converter which connects to the usb cable to the plug. They are available in the market so you will need to look for it. Or you may find it at any electronic store.
purchase/find a micro-usb cable and connect to your pc- or if you have an ipod/iphone/ipod touch charger, remove the cable, and plug the micro-usb cable to that charger.
You can get the correct lead from almost any large computer or photographic store, it does not have to be the official Casio item.
The lead needs to be a standard USB socket at one end (USB type A) and the other end is a micro USB (micro USB type B). This is by far the most common type for many cameras and phones now so shouldn't be expensive or difficult to find.
Alternatively, ditch the cable altogether and use an external card reader. Removing your memory card and putting it into an external reader to transfer images is usually much faster, especially if you also avoid using the clunky and non-essential software which most cameras are supplied with.
I hope that you've found my reply to be of use and ask in return only that you rate my answer.
The problem lies with the fact that a standard mini usb pin-out has + voltage on pin 1 and ground on pin 5. The navigon is programmed to recognize this as a computer. The navigon charger however has + voltage on pin 4 and ground on pin 5. The reason for navigon doing this as opposed to following the standard pin-out is due to the unit requiring a stronger power supply to charge the battery. USB current output on a computer does not have the capacity to do this. As a consequence, you will have to find a charger that has the right pin-out for this device ( + on pin 4 and - on pin 5 ). The tough thing is, there is no way to tell one from the other, they look identical. However, I have found that chargers with a capacity of 1000 ma or greater are pinned-out like above ( + on pin 4 and - on pin 5 ). Other than using a multimeter to verify the pins, the only thing to do, would be to plug it in and see if it works. Hope this helps.
