Hi My problem is that my Jamo 200 sub sounds very weak even my sub level is max. I have Pioneer VSX-519V-K amp and my ps3 is my bluray player. The sub used to sound great only at half level but i don't know why i has changed. We moved to another house and i had to set my hometheater again and after that the sub has been very weak sounding :(
Is everything hooked up correctly sounds off I know also could be your amp is going on you cold be a multitude of problems or one of the simple ones i stated
Testimonial: "Everything is connected correct. Amp settings : Speakers all small, this should give bass to sub. Xover is 80 at amp and back of the sub 150. No loudness or midnight settings are on. LFE settings are at 0 ( basic setting ) I might test the sub with my computer to see if there is any difference."
SOURCE: my jamo sub 200 & pioneer vsx517 receiver is not working properly
What do you mean that it sometimes doesn't work? It doesn't power on automatically?
Check settings of your receiver - if it has subwoofer output enables and if low frequencies from all channels are directed also to the SUB. By default only the LFE channel (.1) of 5.1 signal input is fed to the subwoofer. So Sub will work in this case only when you listen to 5.1 signal (DVD movie for example), but for radio or stereo music, only front speakers are used. By configuring this bass redirect, you can use subwoofer for all signal types.
the easiest solution is to get yourself a cord that switches from headphone plug to RCA and connect it that way. I sure hope that this helps you in hooking your ipad up to the Jamo 200 Sub. Thanks, Cody
