If
you gently push up on the door latch heads (hook-like devices sticking
out of the door)
there should be spring tension. If they just flop right up, the spring
is off inside.
Normally the problem is
not the spring, but a broken
spring mounting tab on the door latch head (hook) assembly or the inner
door panel.
If it's the door panel,
it's usually easier and cheaper to use epoxy and some kind of hardware
to fashion a new spring mount.
The door latch head
(hook) is easy to replace or repair if that's the issue.
The service manual for the R-408LS (the model you posted it under) is here.
You can order parts from the Sears Parts Direct
Web site.
