Washing Machines Logo
m
mervat morad Posted on Oct 26, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have sanyo automatic washing mashine top loaded ASW-A95HT , all of sudde not working , the lambs of each cycle is red illuminated as well as the child lock , I have not the manual , any help ? if this child lock how can I unlock it?
Denny Giesel
Level 3:
Master:
  • Master 818 Answers
  • Posted on Oct 26, 2013
Denny Giesel
Master
Level 3:
Master:
Answers
818
Questions
0
Helped
152723
Points
2428
Push and hold the end of cycle-or pause/cancel button and count to ten-cheers Denny
  • Yogesh Lutchun
    Yogesh Lutchun Mar 09, 2018
    i have the same problem.. pushing and holding the pause/cancel button does not solve the problem.
    any help?
5 Related Answers
Anonymous
  • 60 Answers
  • Posted on Sep 14, 2007
SOURCE: Kenmore washing machine
you need to replace the timer it is faulty let me know how you make out
A
Anonymous
  • Posted on Apr 04, 2008
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
Machine unbalanced or belt is worn maybe
jonniewalker
Starnley Johnwells
  • 1031 Answers
  • Posted on Sep 27, 2008
SOURCE: washing mashine
If there is a drain issue, sometimes there is an obvious solution. Check the drain hose for any kinks, as well as checking any lint filters in or on the drain hose. Is there a lint sock on the end that's full? Perhaps the drain line itself is plugged. You will want to make sure that the house drain system is not backed up or plugged. Always make sure that the washer drain hose is above the level of water in the drain tub. Some Whirlpool/Kenmore washers make use of a side-check valve near the tub outlet which may get clogged. A standpipe should be at least 1 1/4 inches in diameter, and never seal a drain hose into a standpipe. This can lead to back-siphoning. You also want to make sure that the standpipe is less than 96 inches in height. Pump problems show various symptoms. Sometimes the pump will lock up and seize. If the motor is running, it will continue to try to turn the pump. In the case of belt-driven pumps, the belt may break or burn through. The pulley may shear off. If there is enough tension on the belt, and the motor continues to try to turn it, you may wind up with a seized motor as well. The pump itself may have seized bearings, be jammed by clothing or another object; or the impeller blades may be broken off. The usual fix is to replace the pump.
If you think your pump may be jammed, drain out your tub and remove the hoses. Look inside the hoses and see if there are any obstructions. Feel around inside the pump inlets for anything that may be jamming the pump itself. You can also use long-nosed pliers to feel around inside the pump for any items that may be causing a jam. If you haven't found a jam, and you still believe there may be a jam in the pump, you can completely remove the pump from the washer and inspect it more closely.
Occasionally, transmission gears may become worn, or some other internal part may go bad. Some older washer models have an electric-mechanical shifter. If it won't shift, it's best to call a professional appliance repair person to address this issue. If your transmission is leaking oil, there are really only two options at this point, either run it until it dies completely, or replace it now.
Anonymous
  • 1294 Answers
  • Posted on Mar 30, 2009
SOURCE: Washing mashine dispalys symbol not in users
Try buttons "dry" & "spin" together for a few seconds. This could be the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............
Anonymous
  • 5 Answers
  • Posted on Oct 11, 2009
SOURCE: My washing machine is SANYO ASW-90WRTP. showes E4
Check on the machine there is a schamatic and it has error codes on it. it may be on the in side panel.
Testimonial: "cool thanks for that just empty the tub then will check for skidmatics"
What is the maximum load of Sanyo ASW-70ST top load washing machine please?
There seems to be nothing on the ASW-70, only the 85 and the 100. Normal advice is having the drum no more than half full of dry clothes for the water level in the drum. The least clothes to the most water gives the best agitation and cleaning.
https://www.manualslib.com/manual/665848/Sanyo-Asw-A100ht.html#manual
I have a washing machine ASW-A95HT but suddenly it stops working I switched it on but the only thing that's working is the drainage,the buttons are not working the screen not working either.as soon as I...
The standard things to check on all washing machines:
1. check the inlet pipes..if the machine has 2 inlets (hot & cold), both should be connected to pipes.. in your situation, its doubtful that the pipes are not connected, but perhaps it got detached through vibration.
2. ensure that the machine is level, some machines have an auto shutoff safety mechanism which prevents it from working if the machine is not exactly (horizontally) level.
3. If you have just used it for a load prior, perhaps it has overheated.. in this instance, just leave it alone for 20 minutes and it should sort itself out.
Sanyo, washing machine, asw-ep70a
It probably needs a belt. It may have been slipping so much with the bigger loads that now it is shiny
3helpful
How to open child lock on sanyo asw-a85ht washing machine
Model no wa80b3 samsung washing mashine
My washing machine is Samsung Top loading Model WA80B3, the problem is that the water inlet valve is continuously working all the time during the washing cycle and it does not stop automatically, so I have to run additional drying cycle after washing cycle and after closing the water supply manually
Top Washing Machines Experts
john h
