Color wheel should be checked. Might need replacement. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
SOURCE: Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
SOURCE: I have a WD 65737
This
model is equipped with a self-diagnosis feature to help
with diagnosis of shutdown problems, to activate this turn the unit on
let it shutdown then press the input/or device and menu buttons on the
front panel simultaneously and hold them in for 5 seconds after 5
seconds the power LED on the front panel will blink a two digit
sequence. This will be one set of blinks a short pause then another set
of blinks, this will repeat 5 times.
Let me know,so that we could
Proceed.
Hope i helped you.
Thanks for using ' Fixya '
and have a nice day!!
SOURCE: my mitsubishi 60 inch tv
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
