SOURCE: Need parts to repair pan handle
I just had this problem! I took it to Ace hardware and the guys helped me out, big time. I have a PH-358 panhandle and the same piece fell of during a shoot into some brush and dirt outside.
We (they) fixed it using a #6 metric bolt and butterfly wing nut along with two grommets (3/8 ID and 5/8 OD). It worked perfectly! Not only does it hold the handle together but you can tighten or loosen the handle as well using the butterfly wing nut.
SOURCE: Can I get a quick release head for a Vivitar 900 tripod?
A quick release for the Vivitar V900 can be found at: http://www.tripodquickrelease.com/Vivitar_Quick_Releases.htm
http://kenkooutlet.com sells the parts. Part diagrams are at http://www.thkphoto.com/support/SLIK_Parts_Diagrams/SLIK-U212DX.pdf.
SOURCE: Vivitar VPT- 360 tripod
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I've seen.
