Called Flash Codes. First try turning off everything at the breaker for at least 2 hours and preferably overnight. Turn back on and wait 15 minutes for self test to complete.
turn on the .AC. power. The green A.C. Power On Indicator should be lit when the alarm is operating from A.C. power. ckeck to ensure the power did not trip the breaker+. If you more than one and this is the only one chirping replace it, units have a life span of 5 years. remove unit an look at the expiration date. if it was me I would buy a new one. they are not expensive. home dept Lowe's or amazon
? 0:29
https://www.youtube.com/watch?v=AvXJd-tYCJ0
Apr 28, 2012 - Uploaded by bship452
Then showing the amber indicator light blinking 5 five times, stops ... push remote to operate opener, you hear a clicking sound from the unit. ... Show more .... blink 5 times (looks almost alike) If I forced the garage door closed, ...Missing: sequence
ths.gardenweb.com > Home Forums > Garages/Workshops
Jun 27, 2006 - Now, I cannot get the light in the sensor at the door to come on. ... the green LED went OUT about 1/2 way up the door opening sequence. .... other is working (I don't recall if it's green or amber, but know that it is lit.) ... Their is also a green LEDflashing 2 times every 5 seconds or so at control center of unit.
it seems like the battery is going. clean battery terminals, also the grounding to the body (engine block, transmission, etc.) all should be shiny cleaned. suggest you go to autozone (or other auto parts) for a free battery & alternator tests.
Volvo 850 (1993-1995) Service Light Reset
Under the hood there are 2 diagnostic units (labeled A and B on the cover) next to the washer reservoir.
1. Turn on the ignition and open diagnostic unit A.
2. Locate the flylead (the test wire that is in the plastic holder).
3. Insert the flylead into socket 7.
4. Press the large round test button on the diagnostic unit 4 times, briefly but firmly.
5. When the LED flashes and then stays lit, it will accept the reset code.
6. The reset code for the service light is 1-5-1.
7. Press the large round test button firmly one time and then release it. The LED should be lit.
8. Press the button firmly 5 times and then release it. The LED should be lit.
9. Press the button firmly one more time and then release it. The LED will flash several times.
10. Turn off the ignition switch and replace the flylead in its holder and close the cover.
The Service Light has now been reset.
Since the PA clip is not lit, the problem seems to be up front...
First thing is to look for a bad cable as a broken ground could be putting hum at a clipping level. First thing, test this by unplugging all inputs. If the clipping light goes out, then you have bad cables or a ground loop.
Try sending a line level signal into "Effects return" to test if the power amps are OK.
If the clip light is still on, turn all gain controls down to minimum. If light is still on then take unit for servicing.
Power supply has several voltages. Just because the 5v power is active doesn't mean all the voltages are OK. You need to have the power supply tested for 12v and 3.3v. A quick test is to unplug all the wires from the power supply. There is a single green wire on the motherboard main plug. Connect (use a bent paper clip) that green switch wire and any black wire. Plug in the power supply and it should run (fan starts)
There are 4 reasons why your unit is behaving this way: 1. Charger is the problem. 2. The docking station is the broken. 3. The battery is broken or not accepting charge. 4. The actual unit is the problem. It is very hard to tell which one is causing this to happen. Let us do some troubleshooting first: 1. Plug your charger in an A/C outlet and make sure the red power light (left) is lit, otherwise the charger or the docking station is broken. 2. You can test the charger with a multimeter. Unplug the charger from the docking station and measure the voltage across the outside and inside, it should register more than 5 volts DC. If there is a 5Volt DC the docking station is the problem otherwise the charger is broken. 3. If the red power light is lit and the status light (right) is lit too, your docking station is broken. 4. If the red power light is lit, dock the unit into the charger, the status light (left) should turn red when your battery is accepting charge or turn blue when your battery is fully charged. 5. If the status light will not lit at all (while the red power light is on), tap the screen while the unit is docked on the charger. If the unit will become alive, you need a new battery otherwise you need a new unit.
12 hours is very long time to charge, the status light should turn to blue in less than 2 hours especially for a new battery.
