Radio Communications Logo
Jason Douville Posted on Oct 25, 2013
Radio error codeURC HW error - Motorola Radio Communications
Phil Karras
Level 1:
Scholar:
New Friend:
  • Contributor 53 Answers
  • Posted on Oct 28, 2013
Phil Karras
Contributor
Level 1:
Scholar:
New Friend:
Answers
53
Questions
0
Helped
19502
Points
86
Code URC HW error: HW usually stands for hardware which means some part of the electronics has failed. Without a model number I can't look up the code "URC" but I'd suggest you do a search on the web for "Motorola model ##### error codes"
Looking for user manual for Harwa portable radio model no HW-283U
Contact Harwa directly to request the manual or information how to obtain it.
Radio keeps turning off and on error code is URC HW ERROR
It would help if you'd post the radio maker and model. Just not enough information to help you hree...
2answers
Error 416 hw
The Tray Table in Tray 2 took more than 40 seconds to rise or didnt rise at all. First, check the tray 2 lift gears. Second check the tray 2 lift arm. Third check the tray 2 table height motor (M403). Lastly, check the tray 2 Height Sensor (S413)
I have listed these in the order of their likely to fail. Most of the times, its the lift gears
GM950 programing software
What are you looking for?
the radio its self or programming software?
If you need software you need to post the model number, serial number and ver number. these should be on the bottom of your radio.
This info will match radio with software correctly.
M3ODQ
10helpful
2answers
Service manual for gm338
http://www.motorola.com/governmentandenterprise/contentdir/zh_CN/Files/ProductInformation/GM338_Aus.pdf
1helpful
DVD writing problem -'HW error, Timeout on logical unit'
What software are you using to burn and what type of dvd are you trying to burn.(+), (-), or (RW). Do you have a copy of NERO? http://www.filehippo.com has NERO (I think) try a different then try a different disk. Some where it even said to try defragging the hard drive...It wouldn't hurt. Let me know what happens. Good Luck, Tim
IPaq 4355
f you go to http://www.radio-locator.com/ there are a large number of internet radio stations that you can thru the ipaq.
Top Motorola Radio Communications Experts
eradiostore
eradiostore
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
