Press power, and the green light comes on then 2 sec. later it turns off?
  • Televison & ... Master
  • 4,048 Answers
Check the back door on the light chamber is hitting the swich can come away if you move the tv around.
Posted on Oct 25, 2013
  • 3 more comments
  • Kevin Hitchcock Oct 26, 2013
    no back door bud, but thanks
  •  Russ Hill
    Russ Hill Oct 26, 2013
    what make and model is it that would help... it is a projection tv as page says.
  •  Russ Hill
    if its the 3 ctr type Old. then it might be the switch relay can you hear clicking when you try to turn on. should hear 2 clicks.
    mitsubishi ws-55819 1 click when you hit power, one click as green light goes out
  •  Russ Hill
    http://www.youtube.com/watch?v=63TbxQaNk... this should help there is in the video 3 green fuse check them with a meter check they have not blown also with the back off give the hole board a good clean out with an old paint brush clean and dry. helps so you can see if any thing ells looks suspect. from jsu a quick read about the tv, it suffers from bad convergence IC pulling down one of its supply lines . meaning the voltage can go to low. to low voltage can be the capasiters on the power side of the board. look for bowed top meaning going round, they should be flat. hope this helps.
4 Suggested Answers
6ya staff
SOURCE:
BobE3
  • 3 Answers
SOURCE: Tv cuts off and green light flashes
The Best Solution worked perfectly, I replaced the XL2200 Sony Bulb and the TV is up and running again!
Thanks for the help.
BobE.
Posted on Aug 12, 2008
ladywinn
ladywinn
  • 5138 Answers
SOURCE: replaced bulb in kdf50e2000 ,got a red lamp light,
Ballast Board it is what powers Lamp.
Encompass Parts 1-800-638-3328
Posted on Mar 26, 2010
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: eplaced bulb in kdf50e2000 ,got a red lamp light,
How many times red light blinks in tv after you replaced lamp?
Let me know to sort out problem.
Thanks.
Posted on Nov 24, 2010
Mitshubishi plasma tv ws65869 wont start green led on in a sec off
Not a Plasma by the model number listed.
When green power light comes on and goes off a few seconds later:
Press and hold on the front of the set both the Menu and Input (source) buttons at same time for at least five seconds and let both go.
Power light will blink a two digit error code like: 2 blinks, 2 blinks and a pause and repeat it several times.
If set has been unplugged it clears the errors and you must turn on and when power light goes out repeat.
Let me know error code found and I will help
Mar 11, 2012 | Mitsubishi Televison & Video
Is show E5 WHAT IS PROBLEM
Hi there
A) E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
B) E27 - it is code for reset absorber (EEPROM reset or Waste
ink counter reset) and follow the described below
procedure:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Turn off the printer.( it must be turn off)
then turn it on again.
Only in B) case you can enter into "service mode", in A) case or if have e.g. paper jam, or another error you CAN'T enter
the "service mode"
Try it
Anonymous see A) case: E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 01, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I turn on my pixma mp150 and it flashes e4 whats the problem then
Hi there
it.
procedure:
button pressing
the "service mode"
Try it
it.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Mar 21, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Mp140 shows E5, 2 114,0
Hi there With most ( E ) errors
it.
procedure:
button pressing
the "service mode"
Try it
it.
Feb 27, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
Won't turn on
the power supply is bad ,deflection board is where i would look. the board w/ the transformer on it
Jul 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Press power button green light comes on.But no picture no sound,
I have had my WS-65511 fail like this, first at 4 years, second 2 weeks later, then 3rd time yesterday (4/14/2009). In past, the tech replaced a thermal sensor p/n 299P313010A (but Mitsubishi says that part is not for WS-65511 and that it does not have a thermal sensor - go figure). It is a white rectangle with about 30 pins in 2 rows and is soldered onto a board in the TV. List price is about $25. Might be your problem.
Apr 04, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Turns off after 4 secs or so....From Green to Red,
Receiver turns on Green but on pressing button again for red light standby, red light will not come on for this Denon receiver. Recently light came on saying Panel Lock is on. I was not able to get tuner to work.
Aug 25, 2008 | Denon AVR-1905 Receiver
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
