SOURCE: Iron whuts off
check the circuit at the switch it could ave faulty cap that is not regulating the voltage properly.replace it.good luck
SOURCE: Sunbeam Electric Blanket Model 972 A5 Type 692
Did you get helped last year? If so please ignore. Otherwise....
Hi. You can locate a Sunbeam Service Centre via http://www.sunbeam.com.au/Pages/Support/Repairers.aspx
You're looking at $69,95 recommended retail.
BTW have you checked that it's not the blanket? Swap the controls over, if the problem follows the control it's the control. If the problem stays on the same side of the blanket, it's the blanket.
Also note Sunbeam has a 3 year warranty on electric blankets. If Date Of Purchase is less than 3 years ago call 1800025059 option 1 to speak to their Customer Service,
SOURCE: I received this electric blanket
Appears to be that the power is not getting to the temperature controllers. Suspect a problem in the wiring between the wall outlet (if not the wall outlet) to the temperature controllers. Look for broken plug at end of cord or a break in the cord between the plug and the controller. Last, you may have to look at the connections inside the temperature controller the power cord goes to in order to see if there is something loose inside. But do this with the blanket unplugged.
