Question about Nintendo Game Boy Advance SP Console
Nintendo DS is dead
My Nintendo DS has completely stopped working. When I connect to the charger, the power light flashes for a split second then goes out. Please help someone!!!!
    Scholar:
    New Friend:
  • 49 Answers
Its the fuse!
http://www.youtube.com/watch?v=io5iN42q3VQ&feature=related
Posted on Feb 08, 2011
Mabye its caught a bit of moisture and needs to be dryed out
Posted on Oct 02, 2007
  • Anonymous Oct 02, 2007
    im trying to find a rom form a link to the past for GBA but i can't find one
    Guru:
  • 120 Answers
You may need a replacement battery. Check ebay for replacement DS batteries.
Posted on Sep 29, 2007
6ya staff
SOURCE:
I plug in my ds lite charger the light comes on for a split second then goes off? any ideas?
Try shaking the DS, not too hard and if you hear something loose inside then you should send it in to Nintendo. Also, could be just a faulty charger cable. Try another cable see if it works.
Jul 13, 2010 | Nintendo DS Lite Console
My ds lite won't charge.. the orange light appeared blinked
We had this problem with a brand new DS Lite...turns out it was a bad charger. If you have access to another charger, try that first. Good luck!
Apr 03, 2010 | Nintendo DS Lite Console
My sons nintendo ds wont turn on, when we charge it, turn power on , the green light comes on and bottom screen blinks for a split second then goes dead.. Is this fixable , if so what do i try??? thanks
yes it is fixable sounds like your fault is with the top screen are the hinges ok has it been dropped.
most green light and screen flashes point to a defective screen or connection on the mother board or sometimes fuses. id start with checking the motherboard connection if its ok check the fuses if all is ok buy a new top screen and replace it.
Jun 30, 2009 | Nintendo DS Lite Console
DS lite green light comes on, top screen flash,then switches off
Check L2 near the power switch on your DS mobo. That part usually get loosen or taken out when you drop your DS. And usually you can recover it when dismantling your DS.
Jun 16, 2009 | Nintendo DS Lite Console
Wont turn on
I'll quote GBATemp here:
symptom:
the ds lite powers up for a brief instant, but then shuts off
potential solution:
disassemble the lower shell and check the connections of upper and lower displays (all three flexible cable connections).
You can view the full and detailed guide here:
http://gbatemp.net/index.php?showtopic=98240
GMAC
Jun 14, 2009 | Nintendo DS Lite Console
My nintendo ds lite stopped working but does charge
The LCD screens may be dead. Ask a mechanic to change the screens.
Or maybe it is about the hinge. the cables may be damaged.
Did you spill anything on the DS??
Mar 12, 2009 | Nintendo DS Lite Console
Nintendo DS Lite - does not charge
i would suggest trying to find what the issue is, if you know anyone who has a different charger, try it on your daughter's ds. if it still doesn't work, it's a DS problem...if it's under warranty, go to whatever store you bought it at and have them fix or replace it. If you try the different charger and it DOES work, then the only problem is the charger...so then all you have to do is go buy a new charger...hope this helps.
Feb 05, 2009 | Nintendo DS Lite Console
I have a major problem!!!!!!!! Please try to help!!!!!!!!:((
you will need to replace the upper lcd screen, when the power light came off it caused the top and bottom shell to shift back and forth causing the lcd ribbon to become damaged, the flash you see is the power from the botton trying to make it's way to the top, send to ebay ed-kar-3 for $38.00 to fix
Oct 18, 2008 | Nintendo DS Console
Power problems with DS Lite
Really sounds like a dead battery. The DS will not work if the battery is bad even when it's plugged in. You get the quick flash of the power light and that's it.
Mar 29, 2008 | Nintendo DS Console
Nintendo Game Boy Advance SP Console Logo
91 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Ekse
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
