I don't know which particular calculator model you have, but for an HP-12C, the manual says the following:
Digit Separators
As a number is keyed in, each group of three digits to the left of the decimal point is automatically separated in the display. When the calculator is first turned on after coming from the factory - or after Continuous Memory is reset - the decimal point in displayed numbers is a dot, and the separator between each group of three digits is a comma. If you wish, you can set the calculator to display
a comma for the decimal point and a dot for the three-digit separator. To do so, turn the calculator off, then press and hold down the [.] key while you press [ON]. Doing so again sets the calculator to use the original digit separators in the display.
SOURCE: Display a decimal point
Turn the calculator off, then press and hold down the .(decimal key) while you press the on button. Doing so again sets the calculator to use the original digit separators in the display
SOURCE: display shows comma in place of decimal point?
To change the ´comma´, make sure the calculator is switched to off, press (.) key and maintain, switch the calculator ON. This operation changes dot to comma and vice-versa.
SOURCE: how to change comma into decimal point
Turn the calculator off, then press and hold down the . key while you press on.
Doing so, sets the calculator to the original digit separators in display.
