It sound like the color or the screen parts inside of the game boy color are not working properly so it would just be easier to buy a new one vs fixing the current one. The current one could be fixed but it might not be an easy fix and the fix might be complicated then.
normally there are some fault caps around the video amp try to replace them with new ones since am not sure of the exact faulty cap .its located on the motherboard.
your psp is damaged !! try to hack it..! NOTE hack will only work this versions
psp1000 psp1001 psp2000 psp2001
BUT IT WILL not WORK FOR 3000 or 3001 look on the bottom of the psp it should say psp and then your current version heres a link on how to hack it.!! http://www.youtube.com/watch?v=nL7ToOp_nTY&videos=G1BagnnETiI
I am having the same problem with a Sony Digital 8, When I hit play I see blue screen buy when I press play and fast foward I see the same gray scan lines> Did you have a stuck tape or problems ejecting tape? I think it is more than cleaning the heads. When I try to record it indicates no tape in camera.
I know how to solve this problem, its worked for me...see, what you do is smash your head on the screen untill you see blood everywhere and the screen cracks... http://www.youtube.com/watch?v=GytPv_v29lc
we'll miss u buddy, R.I.P
Hi
If there is no picture behind the stripe and the edges are well-defined, then one of the display driver ICs has failed. Philips displays can be made by several manufacturers - usually Samsung. The ICs are bonded to the flexible ribbon in most cases, and replacement is an expensive specialist job - and in many cases is simply not possible.
A shadow on the picture is much better - usually due to interference.
Glyn
found web site for jvc in uk they have recall on camcorder as its a fault is to do with the camcorder showing "lens cap still on" they are repairing it free.
