Building Materials Logo
M
Michelle Massie Posted on Oct 24, 2013
Managemylife Our power was restored and now our oven beeps and flashes F13. Is that the timer/clock? what to do?
brandon duby
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Oct 28, 2013
brandon duby
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
Helped
2070
Points
14
Try unplugging it and plug it back in
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/brandon_a1f2045feb96cdb4
2answers
Have Frigidaire Gas oven FFGF3053LSF. We had a power surge & F13 code came on display. Power restored, clock works, F13 code is gone- but now a DR code comes on when I push bake or broil button
Exact same thing happened to me. After a power failure my Frigidaire stove worked and the clock worked but bake broil and self clean gave me a DR error. Tried everything to reset nothing worked. When I unplugged and plugged back in I got an f13 code.I changed the control board and the entire oven is back in business!c86f7aab-24e4-4403-bcd6-0b838d53ac57.jpeg
Every time I use th oven, why does it beep for a day or two going from one settin to another?
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
if Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :
http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
F13 tappan error code, what is it? tappan goes from code 12 straight to 14? there isn't a 13
the code is for the clock timer for bake and broil. The "clock board" will have to be replaced. About $120.
I have a frigidaire stove and the timer sets itself at any time of day or night...
You may find the necessary information related to your problem among these manuals Oven service manual download repair manuals installation schematic... Just choose your oven manufacturer and model.
Mar 24, 2014 • Ovens
F13 beeping sound
Turn power off then back on. If F13 comes back, it's an internal problem with the control board. Replace the control board.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
I have a Frigidaire Elements stove. When I went to preheat the oven I got a constant 'beep' and a code, F13 ERR. Please help Thank-you Anxious in Indy
Hi akadiki,
This error code F13 description is a bad Clock ERC. The steps below will help you determine whether the ERC or touchpad is defective.
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F13 code comes back (usually accompanied by a beeping sound).
7. If F13 comes back, replace the ERC. If it does not, replace the touch pad.
Hope it helps.
Thank you for using FixYa.
F 13
Had the same F13 code and beeping this morning; pulled the main breaker, waited 5 seconds, reset the breaker, and problem gone. Just had to reset the clock.
11helpful
2answers
Error f13 on my frigidaire oven how do i fix it
The "F13" error code means "Bad EEPROM identification/Checksum error".
If reseting the power did not help then according to Frigidaire suggested corrective action the electronic oven control (aka EOC) has to be replaced.
- The part number for the EOC is AP3874704
3helpful
My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
E1 and F1 flash, with beeps at 15 sec. intervals, & oven not working
crys, the tech sheet for your model states that you need to replace the electronic control (clock) when this error is flashing. Catriver..post back.
Top Sears Building Materials Experts
hsapiens
Level 1 Expert
Are you a Sears Building Material Expert? Answer questions, earn points and help others
