Please download the instruction manual and follow the steps.
Blessing.
[email protected]
cell+whatsAPP:+50588611441
Free Treadmill User Manuals ManualsOnline com
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
SOURCE: I NEED THE NORDICTRACK 9600 INCLINE TRAINER TREADMILL SCHEMATIC
contact me @ [email protected] I will send this to you.
SOURCE: NordicTrack Z7xi treadmill console buttons not working
Hello there. It sounds as if you may have a button stuck on your console. Thus not allowing any other buttons to be pushed. (i.e. the 4 beeps). This is usually caused by the i-fit buttons (silver buttons on the front). If the machine is only 4 months old you should still be under warranty (1 year) I believe. This problem in most instances requires the console be replaced. You can contact nordictrack through iconservice.com or by using the number on the fron of your users manual.
Good Luck! Tim
SOURCE: Please help for how to
The best way is to detach the two upright posts that hold up the console from the frame. You will also have to unplug the wiring harness inside one of those uprights. Once you have done that, you can move the machine in just two pieces. If you have any questions, feel free to contact our Customer Service Department @ [email protected]
Chase
NordicTrack Social Media
