Whirlpool Master
- Posted on Oct 26, 2013
Re: Kenmore code F1 and broil wont go off
He clock on my STOVE started flashing F1- You have either a bad ERC (clock) or a bad touch pad.
- Disconnect power to stove
- Gain access to the back of the clock (electronic range control or ERC).
- Unplug the touch pad ribbon connector from the ERC. This will be a flat wire apx. 1 1/2" to 2" wide.
- Make sure everything is clear and will not short out when power is turned back on.
- Turn power back on to stove.
- Watch for the F1 and listen for the beep.
- If you get the F1 and beep, replace the ERC.
- If after apx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock as one part.
Here is the part to order.
All parts come with a 365 day, any part, any reason return policy.
