Hi,Shortie
Actually I need to create a login form in flash 8.0 but i need some script for that and i don't want add any code in HTML only flash.
You can send me on this mail also:
[email protected]
Regards,
Ramveer Singh Rana
Prerequisites (what your host server needs) ok firstly ensure that the server your hosting the script on supports php and ensure u have a pop 3 server set up (on your host)
now there are a lot of free scripts out there I'll post a link for you in a bit. Install the script on your server, create a link for it on your site and thats about it.
You can open the Crystal Report (should be installed with Visual Studio first) after you designed your database, then you have to connect the Crystal Report to the right database (the one which you store financial information in your case), then you can create your report easily by putting the desired variables and designs. Then you have to call for that report with a code within visual basic.
hi this is raj from delhi i have some problem i can not understand the flip book(like how can add the page in flip book). i am first time design e book so please provde me help becase i am not able to pay any charges.
This depends on what you are actually trying to achieve.
1) You may try to search Google and Wikipedia for topics dealing with "CODE OBFUSCATION"
if your are trying to keep your script algorithms a secret.
2) If you are more interested with making sure that the script has not been tampered with, you can scan it with a hash/ checksum generator to create a unique signature, such as CRC or MD5
3) You can also ZIP the file into a password protected archive, and/or convert the archive into a self-decrypting EXE file.
4) You can split the script into two parts:
The first script accepts a password and decrypts the second script into an temporary file, runs that file and then securely deletes the file by over-writing it multiple times using special bit pattern, or launching BCWipe to do it.
You obviously got to consider what happens when your script is interrupted, to make sure no open data residue is left behind.
5) Finally, the ACL program itself may have some facility or plug-in to do what you need, contact the manufacturer's tech support.
Put a button on your scene, and give it the instance name but in the Property Panel. Create a new layer in your movie and name it code
Now add this code to the first frame of the code layer:
but.onPress = function () {
_root.createEmptyMovieClip("container", 1);
loadMovie("loaded.swf", "container");
container._x = 150 ;
container._y = 20 ;
