SOURCE: Incoming Call not Ringing
Either call line 3 first, or make your phone ring :-)
What might be the easiest is to swap modular plugs in the back room between 2 and 5. That way, you get your old extension back and everything will work as it did.
If you can't do that, then you're going to have to do some system programming to turn on the ringing on your phone. If you have a TA series system, you should be able to do it from either the PC or a phone connected to jack $1. If you have another model, you should have a system manual on how do make programming changes.
Carl
SOURCE: Can not pick up line on incoming calls from one extension only
That's what happens when you plug in the system and don't program it. You need to review ICD groups.
By default, the phone connected to the first extension is the master phone and the only phone that rings.
Carl
SOURCE: Incoming call indicator light
Yes!
The easiest way is to assign a DSS button for each person. When their phone is ringing, the DSS button will flash (on most systems - older systems don't do it and newer systems can be programmed not to).
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
SOURCE: Why is my phone ringing?
Your Handset has been programmed i guess by mistake to be in the same ring group as the main receptionist for C0-01 . Use Google for programming manual to make changes.
www.heymot.co.uk
SOURCE: I want to pick up incoming calls from another extension
Yours may be different if your TA-308 is not a U.S. version, but the family is generally 40 picks up all calls in your group and 4+the ringing extension will pick it up. Just in case they have call pickup deny set (721) you'd have to cancel it with 720.
Carl
