SOURCE: Tv stand on the wall
It is not made for wall mounting unless it has 4 bolt holes in the back cover. Some wall mounts grip the tv on top and bottom, but they look like hell.
I bought the same Samsung, but took it back.
SOURCE: Cannot attach base to samsung lcd monitor sw2233
Llay the monitor face down on the floor (I put it in the styrofoam from the package) and then put it up against a solid surface. Then push the part into the socket before attaching the round base.
I tried pushing down onto the monitor while holding it upright but that didn't work. When I called Samsung tech support the solution above is what they told me to try and it worked.
SOURCE: how to remove stand from a samsung syncmaster 910mp
It's usually 2 screw at the base of the TV, at the rear. Loosen or remove the screws and the base should slip right off
SOURCE: stand for the monitor on a samsung syncMaster 940n broken
It depends bad the parts are broken, this is 2007 model, you may have hard time getting replacement parts, details pictures will help.
http://s807.photobucket.com/home/budm/allalbums
SOURCE: Samsung SyncMaster 740N 17" LCD
The problem is in the power supply and inverter board, cause normally bad capacitors that sometimes bulge at the top indicating they are open.
