SOURCE: What are the factory settings for the
find L on your carbruetor and turn it clockwise 1/4 turn to see what difference it makes
it should begin to idle by itself?
zama carb. 1 turn out from closed
walbro 1and 1/4 from closed settings are only preliminary
SOURCE: hi im after the fuel mixture for a 125L husqvarna
From you manual:
Two-stroke oil
For great results and performance use HUSQVARNA two--stroke oil, which is specially formulated for our two-stroke engines. Mixture 1:50 (2%). To maximize the life of your trimmer, you may choose to use a high quality synthetic oil formulated for two-stroke engines. Mixture 1:50 (2%). Never use two--stroke oil intended for water-cooled outboard engines, sometimes referred to as outboard oil. Never use oil intended for four-stroke engines.
WARNING! Always ensure there is adequate ventilation when handling fuel.
1 gallon of premium fuel to 2.6 ounces 2-cycle oil. 2.6 ounce pre-measured containers are available at most chainsaw outlets.
You can find your manual here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
HTH
Lou
SOURCE: husqvarna 125L quit running, it runs then shuts off
Check the gas line. The Husqvarna is having a problem gas additives causing the gas line to deteriorate and colapse.
SOURCE: husqvarna 324L 4 stroke, runs fine, but leaks gas, from carb whil
gasket is worn out. You can buy a generic gasket set from your local lawn shop
