Sound but no picture
About which inverter board, you're discussing about? Power? Backlight? DC to DC inverter? Provide more details please. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
SOURCE: where do i find the inverter board to samsung
Plasma TV does not use inverter back light board, you may have power supply or x/y driving board problems.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Samsung+SP-R4232+
SOURCE: 52" samsung
the problem of your tv is the backlight...a backlight is a set of cold cathode bulb that is inplace at the top and bottom of your monitor..this light illuminate the screen once this light is busted your screen will go black.this lamp is replasable...you can replace them once they are busted...
hope this could help you..good luck!
your rate is important to this help..pls
SOURCE: I had Samsung LCD Series, 530 Model LN52A530 52"
Does it look like this?
http://s807.photobucket.com/albums/yy352/budm/Samsung%20LN-T3242H/
If you tap on the main board, it may come back on.
If this is an LCD tv the backlight inverter is bad, a good way to check it is to shine a flashlight close to the screen and see if you can see a faint picture.
Let me know what you find
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
