This excess temperature may be caused by a temperture detector.
Ther are two detectors on a Toshiba Tec Printer.
- On the print head.
- In the top part of the label sensor mecanism.
You cna check if they are working when going in the adjust set parameter setting.
You can read Head temp and air temp
If one of them is not working you will not be able to adjust the temperature. Worst you'll have the message Head excess temperature message.
SOURCE: how to adjust print head temperature on TEC B-452-HS12-QQ
it depends if you are working with driver, label software or escape commands. If you are working with escapes you can try with command AY, refer to the programming manual.
If you are working with Seagull driver you can adjust the print density in OPTIONS
SOURCE: TEC SX4 Label printer received
How do you communicate with the printer?
If by serial check the speed parity etc frma the parameter menu
Else check that the character selecter for esc sequence is correctly programed els choose Auto.
TO en ter parameter settings
Switch on with feed and puase key pressed. When (1) diag V XX displayed press feed
(2) parameter is displayed.
With the pause button you can navigate in the menu and feed and restart allows you to change the value.
Else do a parameter clear to put everythig to factory defaults
SOURCE: Toshiba TEC B-SX4 paper jam
Size problem or type of material problem or recalibrate the sensors.
All in the owner's manaul
SOURCE: bonjour pouvez vous me dire
Pour installer en r?seau deux solutions.
1 Installer la carte r?seaux et param?trer l'adresse ip, l'adresse passerelle et le masque de sous r?seau.
Soit sur le paneau ou en utilisant les commandes ci-dessous en modifiant les valeurs:
{IP;2,192,168,001,201'} adresse ip
{IP;3,000,000,000,000'} passerelle
{IP;4,255,255,255,000'} masque de sous r?seau
{IS;1,09100'} activation du port telnet en 9100
ou
brancher un boitier axis ou netgear sur le port parallele
