Question about Nikon D2X Digital Camera
D2x won't work when a lens is attached - Nikon D2X Digital Camera
    Top Expert:
  • Nikon Master
  • 6,705 Answers
Did you try to reset the camera to factory settings? Won't work, does that mean everything stays out? Or you can't make a picture and still view pictures you made? Is there an error in the display, like fEE. That would be caused by the sensor, looking if your diaphragmatic setting on the lens is locked on the smallest aperture. Could be dust, or worse the sensor is damaged. Then the camera must be repaired.
Posted on Oct 25, 2013
6ya staff
SOURCE:
Flashing P on screen d2x
Are you sure it is a P you see? not an F?
In the whole manual I can't find an error called P.
When you see an F, it has to do with the lens. Not in its slot, not fitted correctly. And when FEE is on the screen, the lens is not set to the highest diaphragm. Sometimes the sensor is dirty and will give this FEE random. Or sometimes the error stays, because the sensor is broke.
Please tell me it is really a P you see.
Nov 11, 2013 | Nikon D2X Digital Camera
D2X won't power down!!
Sounds like there is a problem with the image compression board. Send it to Nikon - replacing the board requires programming with Nikon's proprietary program.
Apr 09, 2013 | Nikon D2X Digital Camera
My sigma 24-70mm f2.8 doesnot work on my d7000
Could you be a little more specific about "does not work"? Does the lens not fit? Can you not view through the lens when it's attached? Does it not autofocus? Does it not meter the exposure properly?
Feb 15, 2013 | Sigma 24-70mm f/2.8 EX DG IF HSM Lens for...
Help my Nickon D2x stopped working today in the middle of a shoot. I pointed it up at my subject with the sun behind their head and wondered if the sun caught the lens and effected the sensor??
Quite possible that the CCD- charge coupled device - which is the optical sensor was damaged by this direct exposure to the Sun. In some cases there can be a trip but need a check at the Nikon service. you can switch off remove battery and keep overnight to see if the camera resets.
Jul 09, 2011 | Nikon D2X Digital Camera
D2x shutter isn't firing. What are the causes?
Hiit is depend on what causes. Like your problem it relate with several cause. would you give more detail? Like back of menu function, top of lcd display function (every button does it change).
Jun 03, 2011 | Nikon D2X Digital Camera
Nikon D2X - How do you lower the mirror if it gets locked up by mistake ? Had an err message on the upper view screen, tried the repair from this site, by tapping the front leftside of camera front and...
Normally, you can manually lock-up the mirror for the purpose of cleaning the sensor. To do this, you need to connect the camera to the optional EH-6 AC adapter. If after removing the lens and inspecting the mirror, you cannot gently nudge it back down (do not touch it...use a cotton swab) then you'll need access to the EH-6. If you don't have one, possibly a camera store near you would have one and be willing to let you plug in your camera so you could try to access the mirror lock-up function in the set-up menu.
Nov 08, 2010 | Nikon D2X Digital Camera
My Nikon D2x is having shutter problems, HELP!
the only time i have ever seen this on my D2x is when the lens isnt snapped all the way on. but since you have tried several lenses, i am sure they are snapped on. this leads me to believe something is wrong with one of the contacts on the camera where the lens snaps on--check them to be sure they are springing out and clean. check the owners manual to see if there is another cause for this message.
Mar 15, 2009 | Nikon D2X Digital Camera
Apperture on Nikon d2x doesn't close after 3.5-4.5
You need to "lock" the lens at the smallest aperature. With the lens removed from the camera, rotate the ring to the smallest aperture, which is the largest number (like 16 or 22). Next to that number you will see a small slide switch. Move that switch. It loocks that ring at that setting.
Remount the lens and try.
Feb 01, 2009 | Nikon D2X Digital Camera
ERR MESSAGE, NIKON D2X
the only time i have ever seen this message on my D2x is when the lens is not all the way snapped on. try re-seating the lens.
Dec 25, 2008 | Nikon D2X Digital Camera
Nikon D2X Digital Camera Logo
66 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
