Http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15603
Here is the link all the downloads including the manual avvialable straight from canon.
Thanks and enjoy,
Lee
You can downlad everything for your PIXMA MX310 at
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15603
SOURCE: User Manual for canon Pixma MP150 Printer
Here is a link for your user manual. Allow pop ups for this site. This should help you with your problem.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=12764#DownloadDetailAct
SOURCE: I need to download the manual/user guide for canon
I see you need the manual for your canon PIXMA MX310.
Well just go to this site and download.( please rate and the download link is at the end)
I hope this helped
-Ryan
-Please rate if this helped
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=15603#DownloadDetailAct
SOURCE: where is the serial number on canon pixma mx310?
The serial number is located inside the maching, behind the tape attached to the cartridge carrier. When the cartridges are all the way to the left side (position for changing cartridges), the serial number is visible at the center-right position. Open the maching as if you were going to change cartridges.
SOURCE: How to change the ink in a Canon PIXMA MX310?
Note: - Do not attempt to reattach the protective tape once you have removed it.
- Do not touch the gold electrical contacts or the print head nozzles after removing the protective tape.
*One
black cartridge and one color cartridge must be installed in the
machine in order for the printer to operate. It does not matter if the
capacities (Standard or High) do not match.
<1> The ink cartridge is not installed properly.
<2> The ink cartridge is installed properly.
Removing Ink Cartridges:
Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
