Only two things can be wrong here, either the solution hose is plugged, kinked or undone from it's source, or the pump motor is not working. I'd try the hose first, if you can, take it off at the pump and then turn the machine on. If you get solution pumping out of the unit, then it's not the little pump motor and your problem is in the hose.
when i press the spay button on handle it trips out
