It just stopped working and I cannot open it on my computer or any other computer. No computer will recognize my memorex travel drive even though it will recognize other travel drives. I have very important info that I need to retrieve please don't tell me it is lost for good.
SOURCE: Memorex compatibility with Mac computer.
Hi-
Are you receiving some error message? try reformating the jump drive to an os journaled or fat 16 using the disk utility tool. check as well the jump drive maybe its write protected, check at both ends for a small switch. if there's none, try reformating it then. if all fails then try hooking it on a different computer, computer running XP or windows. If none still, it may be a hardware issue. call manufacturer if its within warranty for a replacement.
Hope this helps!
SOURCE: some pc's don't recognize my travel drive
I have a USB hard drive, and I have noticed that on some systems the current Draw on the USB port is too high for systems with unpowered / Low power USB ports, and therefore it doesn't work for that system,
this issue can be bypassed by using a "powered" USB hub
SOURCE: Memorex ultra travel drive 120 - lost auxiliary power cable
looks like this may be compatible
http://www.amazon.co.uk/Ex-Pro-USB-Cable-Provides-additional/dp/B0019WNMLC/ref=sr_1_2?ie=UTF8&s=electronics&qid=1237901508&sr=8-2
hope this helps
SOURCE: remove write protection from memorex USB travel drive (4GB)
Go to Driver Detective and check your drivers.
