Question about Microsoft Standard Wireless Optical Mouse
Have a microsoft 1025 optical mouse and a 1014 or 1.1 wireless keyboard can i use them on a 7 -32 bit system I put new batteries in the units downloaded EXE intellatype8.2 hit connect buttons but no luck light on mouse lit up
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 34 Answers
If 7 has the driver it will recognize it instantly ... if not go to iobit.com and download the driver booster program for free and use it to get the new driver for 7 that you need
Posted on Nov 16, 2013
6ya staff
SOURCE:
SOURCE: Microsoft Standard Wireless optical mouse Model 1025
You need to download the IntelliPoint driver from the Microsoft Corporation website. After you install this driver, you will be able to use your mouse as normal.
Posted on Nov 08, 2008
Anonymous
SOURCE: microsoft wireless notebook optical mouse 3000 Doesnt seem to work?
Okay, a coworker had this problem and it was a fairly easy fix, first, plug the USB reciever into a direct USB port, then pess the connect button on the underside of the mouse, when the red light starts blinking let go and then press it and hold, and at the SAME TIME press and hold the connect button on the receiver until both the receiver light and the mouse light turn on steadily, and voila!
Posted on Nov 24, 2008
Anonymous
SOURCE: Microsoft Wireless Mouse Model 1025--Keeps giving low battery messages
throw it in the woods and buy a new one ya cheap ****
Posted on Dec 22, 2008
Anonymous
  • 167 Answers
SOURCE: Microsoft Wireless Optical Mouse 2000 stops responding
i would agree that a new one may be needed. i have a desktop set that, the mouse had failed. i got a better microsoft mouse, and i was able to use it with the desktop set.and have all of the functions of the new mouse through the original receiver. hope this helps! good luck.
Posted on Feb 13, 2009
Anonymous
SOURCE: Microsoft wireless notebook optical mouse 1023 - not working!
If you know that the battery is good then try this next. There is a VERY tiny shark-fin shaped spring-loaded button on the bottom of the mouse that is pressed in, when you insert the receiver, while the mouse is not in use, that turns off the mouse to save the batteries. If you haven't used the mouse in a while, it can get stuck in the in position, so that when you pull out the receiver, it doesn't spring out and turn the mouse on (indicated by the red light on the bottom). If you notice that the light isn't coming on. Just try manually pushing in the little shark-fin thing a couple times to make it spring back out. After a couple times, you should be able to get it unstuck and the red light should come on.
Posted on Apr 04, 2009
What's the prices/rate of Microsoft wireless optical desktop receiver 2.1 model 1028, Microsoft standard wireless optical mouse model 1025 and Microsoft wireless multimedia keyboard 1.1 model 1014
Microsoft wireless optical desktop receiver 2.1 model 1028 - varies from Rs. 1900-2200
Microsoft standard wireless optical mouse model 1025 - varies from Rs. 400-600
Microsoft wireless multimedia keyboard 1.1 model 1014 - varies from Rs. 700-900
Dec 07, 2010 | Computers & Internet
Sometimes mouse just jams up wont work at all other times it work fine. I have put new batterys in did not works any better. I have model #1025 wireless optical mouse on XP. Did not get a CD to program it...
more detail on this as I don't know if it is current laser or if u are using past ball under mouse...if laser it may be the optical sensor may have a glitch...try using another mouse to see if that works...if it does then the problem is that mouse...because I can get any mouse I want and hook it up to my laptop and it works good...try it and see. Get a logi tech wireless mouse.
May 22, 2010 | Microsoft Standard Wireless Optical Mouse
Microsoft wireless mouse 3000 - all lights are on; flash upon reset, but still doesn't work. Running Vista 64-bit.
Try to take off battery and next push and hold down the small button that protrudes where the receiver is placed in the mouse, put back battery and simultaneusly release the button,it might make the mouse operate correctly. Good luck!!!! Chawah.
May 28, 2009 | Microsoft Wireless Notebook Optical Mouse...
Jan 21, 2009 | Microsoft Wireless Optical Mouse
Microsoft Standard Wirless Optical Model 1025
do you have the s/w CD ? I think you can download it online.
Sep 07, 2008 | Microsoft Standard Wireless Optical Mouse
Sep 06, 2008 | Microsoft Standard Wireless Optical Mouse
I Need Help with my mouse
I'd suggest ou first change he battery or at least make certain it's fully charged!
Second, stroll on over to the control panel and check the mouse settings!
Mar 11, 2008 | Microsoft Standard Wireless Optical Mouse
Microsoft Standard Wireless Optical Mouse Logo
147 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Peter Dragonetti
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
