Rheem R-410A Complete Split System Heat Pump 2 Ton 14 SEER 11.6 EER. RHKLHM Series Logo
D
David Andreas Posted on Oct 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rheem heat pump kicks on 410a unit comp & os fan run also inside fan. Vapor line gets hot and then comp shuts down os fan continues to run also inside fan. No warm air inside air just circulates? You can SD & repeat this in about 5 min but same results? Suspect something is protecting system from LP or HP ????? It ran in A/C ok a month ago?????
Lawrence Walters
Level 2:
Sergeant:
Champion:
  • Expert 426 Answers
  • Posted on Nov 06, 2013
Lawrence Walters
Expert
Level 2:
Sergeant:
Champion:
Answers
426
Questions
0
Helped
77423
Points
980
When was the last time this unit was cleaned
5 Related Answers
Donni Steen
  • 687 Answers
  • Posted on Apr 05, 2009
SOURCE: rheem power vent water heater shut down due to toxic vapour
Are you getting an error code? I could just be the pressure switch on the unit not allowing it to come on. You can try removing the hose from the inducer and blowing into and drawing air in and out of the tube. You will hear a clicking noise when you do this. Reattach the hose and try the system. Also, you have to unplug the unit for at least 10 minutes and then plug it back in to reset the controls. If the "Guardian" system still senses the fumes, it will not allow the unit to kick on. I could be awhile for the fumes to disapate before it will work. Try putting a low volume fan on the base of the unit to try and keep fresh air moving around the "Guardian" sensor.
Anonymous
  • 332 Answers
  • Posted on Jul 08, 2009
SOURCE: 1 unit intermittently shuts off and other won't ignite
if you have the exhaust run together it will not light up,, they have to be seperate,, the computer board sences the unburnt gasses and will not allow it to start,,
Anonymous
  • 61 Answers
  • Posted on Sep 19, 2009
SOURCE: warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Anonymous
  • 244 Answers
  • Posted on Nov 11, 2009
SOURCE: richman gas lp tankless hot water heater. used for
I had the same problem with my Paloma a year and a half after installation...contacted Rheem\Paloma\Richman customer service (800-432-8373) and they recommened a local installer in my area. The technican diagnosed the problem as the "flow control valve"; he managed to get Rheem/Paloma to cover the part under warranty...I only had to shell out the money for the install.
Gene Haynes
  • 5391 Answers
  • Posted on May 19, 2012
SOURCE: Rheem Tankless wh model rtg-74pvn shuts off error code c4 76
Open following link for rheem tankless resources, includingerror codes and typical maintenance.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
I have a Rheem Power Vent2 when I turn on shower hot has pressure but after it runs few mins losing hot water pressure runs slower would it be that bladder tank or do I need to replace water heater
If cold water has good pressure, and you are not on a well ,try turning water Off to water heater,open tap to relieve pressure remove hot side left water line to heater stick long screw driver inside pipe going inside water ,the heat trap is sticking it's rubber flap inside the pipe going in water heater.
If I run out of propane, do I need to unplug the hot water until I get gas? Also, how do I get it started again once gas is restored? i have a Rheem PowerVent unit.
There is no pilot light on your power vented hot water heater. You may as well unplug it because the induction fan will continue to run. Hopefully your propane company is responsible enough to perform a gas leak check on your propane system. After the gas is turned back on, you can plug in your water heater to start it up. Run-outs are costly so it's bet to get on automatic delivery or call when the tank is down to 30%
Disconnected condensation drain on hot water heater.
Tankless or hybrid water heater?
Tankless gas must have special fitting between water heater and vent that has a condensate line fitting. Hot toxic vent gasses traveling up vent pipe cause acidic water vapor to form inside vent pipe that drips back down vent and drips onto heat exchanger and other parts eventually burning hole through expensive metal alloy heat exchanger, rendering tankless computer water heater useless after electric circuitry gets wet and shorts out.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#vent
Hybrid or heat pump type computer water heaters must have condensate drain connected to catch pan located just above storage tank and below compressor. Condensation can form on condenser coils and drip into catch pan where there is primary and secondary drain
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html#maintenance
Read product manual
Gene
h
Pvg62 model hot water heater
1) Before calling service technician, Copy following link for Rheem tankless error codes and troubleshoot resources including no-error-code:
2) Add a comment and say what you discover.
I have a rheem w/h Md 42vp50pf. It heats my shop floor through the radiant heat tubes. I noticed the shop was getting cold so I checked on it. The pump was on circulating water but the pipes are cold. The...
Similar 42vp50 direct vent product appears on following link:
http://www.rheem.com/product.aspx?id=C24E3F52-A6A4-4BC7-AF5B-0DF23A7A0263
sample manual for power vent series:
http://globalimageserver.com/fetchDocument.aspx?id=c0471d58-5e59-4be6-96f7-68361b8fb515
Manual has troubleshoot section:
If this is combustion-shut-off or FVIR or flammable vapor event, then manual says to call qualified technician.
Service call is certainly less expensive than any fire or injury caused by fire.
Other brands of water heater, for example Bradford White, have customer-resettable FVIR on some models.
Another thing that can be causing problems is air intake, especially in dirty environment like a shop, or if shop chemicals are being inhaled by burner. Burner parts are susceptible to chemicals in trace amounts below odor threshold. You might need fresh air intake for water heater, and air intake needs to be cleaned.
'System lockout' shows on troubleshoot page 32:
1. Gas supply is off or too low to operate.
2. Hot surface ignitor not positioned correctly.
3. Low voltage to the water heater.
4. Electric polarity to unit is incorrect - test and correct.
5. Combustion shut-off device tripped, contact service
agency.
Rheem phone number: 1-800-432-8373
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
PTG-74PVN Error Code -0 14 and LED on the controller board flashes 4 blinks every 6 seconds. Fan turns on few seconds after power up then stops. No fan, no spark, and no fire when water flows. Where can I...
code 14 is a big deal shut that thing down! you will burn it up if you keep running it, your over heat wrap on the heat exchanger is too hot. call rheem they can walk you through it
1helpful
Rheem power vent water heater shut down due to toxic vapour
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
