You can edit the boot.ini file thats located in the C:\ drive. becarefull not to delete the proper entries or you can run into trouble. there are some free utilities out there to edit the boot file without causing problems. try a google search on those if you get stuck.
Hi Jadestar;
Many thanks for trying to help me
The problem is that the LAPTOP resets itself when I switch it on and sometimes during working or surfing the internet.
I assumed from what I read in many FAQs that I need to do this update.
I re-instaled Win Xp, when I switch on now I have three options of Win Xp in the black screen. How can I get rid of the two remaining options.
Many thanks for your value help.
Best Regards.
W.L
Hi CBZ123;
Thanks for your suggestions!!!
Hi Jadestar;
I will try to have a go to the ''boot.ini file'' I am not very keen on this but I can only try my best,also I'll search Google for that file maybe simplify my task.
Once again many thanks
Regards
W.L
what reason do you have to update the bios? there's an old saying that if its not broken dont fix it...your issue you may be having may have another simplier and safer solution you should attempt first. let me know please.
