Question about Vtech Cordless 6041 Phone
Just wondering how to Change ring tones on our new vtech phones cs6529-25
6ya staff
SOURCE:
Anonymous
  • 373 Answers
SOURCE: no dial tone
did you try unplugging the phone for 10 min. and try that
otherwise it could be on the outside box
Posted on Feb 07, 2009
Anonymous
  • 14 Answers
vtech are not very good u mite need another fone
Posted on Sep 09, 2009
odelle_17063
  • 115 Answers
SOURCE: phone short rings every half hour, even when no
if all your 4 units ( phones ) are rringing at the same time,the problem is on the line itself.so try to contact your network's costumer care to repair it.
Posted on Nov 01, 2009
nature_lady1
SOURCE: my vtech cordless phone will not ring. message is ringer off. how to turn ringer on.
Does your handset have a PROG button? Press that, then press the VOL+ button until you come to RINGER VOL: OFF. Press SELECT button, then use the ^ (VOL+) key until you get the desired volume level. Press SELECT again, then OFF. You're good to go.
Posted on Dec 18, 2009
bbl242003
Bruce lee
  • 1637 Answers
SOURCE: My Vtech phone is NOT
You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones MORE USEFUL INFORMATION FOR ALL YOUR ELECTRONICS When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
Posted on Jan 19, 2011
Hi just got a alcatel 2036x cheap phone but cant change ring tones can i do it on this cheap phone thanks
go into settings, ring tones , and change it there , can only change to those listed,
Oct 03, 2016 | Alcatel Cell Phones
How do I set ring tone on base unit to match handset
You didn't state the brand and model of your phone, but my vTech and Uniden phones only have ONE RING TONE on the base, and it can only be turned ON or OFF (and the volume is variable on the vTech).
May 13, 2015 | Lands Phones
How do i enable call forwarding from my vtech phone to my cell phone
Hello! You can turn on call forwarding by pressing 72# then wait until you hear the two tones and dial your number that you wish to send the calls to and then hang up the phone. The two tones signal that it has understood your command and is putting the line into forward mode.
To turn off cal fowarding, press 73# and wait again for the two tones and hang up.
Apr 21, 2011 | Vtech CS5121 Cordless Phone
My phone has another language on it and i cant change it back to engish. I was trying to change my ring tones and that happened!
Since you declined to specify the model of your VTech DECT 6.0 phone, enter it into the search box at
http://www.vtechphones.com/vtechphones/index.cfm/support/general/manuals/
to download a copy of the manual and the instructions on changing the language.
Mar 21, 2011 | Vtech DECT 6.0 Digital Cordless Phone
I am having problems with my phone not ringing It sayes it is muted please help
make sure phone is off (no dial tone or caller) , then hit program it will say directory arrow down with the volume key until it says ringer tone. it give 4 options for ringer tones and off hit select (and choosing a ring tone)
Feb 13, 2011 | Vtech 9009111 Cordless Phone
The handset lights up and the incoming number is shown but you dont hear it ringing
Many times there is a volume switch on the actual handset itself. Most commonly on the left side of vtech devices. there are three different volume levels. By pressing up on the button you should be able to turn the volume up until it has an audible tone confirming volume change. Handset should ring with incoming call when audible tone is heard by pressing up on volume button.
Oct 13, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
No tone on phone ,the rings lights up but there is no tone
i have no ring tone when the phone rings idont heard it what do ido please help me ok
Feb 09, 2010 | Vtech 5.8GHz Cordless Phone with Digital...
Phone short rings every half hour, even when no
Nov 01, 2009 | Vtech 5.8GHz Analog Cordless Phone
My v-tech phone will not set to EST. It goes back to Pacific time as soon as the phone rings.
The key is "as soon as the phone rings". Who's ringing it? I had one of those on Packet8. I had to go to their website and get the instructions to change the time offset in the Packet8 ATA. Check with your dial tone provider for a solution. Carl
Jun 16, 2009 | Vtech DECT 6.0 Cordless Phone with Digital...
Vtech Cordless 6041 Phone Logo
22 people viewed this question
Top Vtech Lands Phones Experts
Marvin
Marvin
Ekse
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
