You need to consider what materials you will be spraying. Wet table powders and sprays with relatively high solids contents will work better with a diaphragm pump than a roller pump. For tanks, plastic should be fine unless you are spraying materials which will react with the plastic. If you are concerned about it getting banged around, consider welding a roll cage or some bumpers around the tank. With 2 acres to spray, the sprayer will not be getting heavy use, so you won't need super heavy duty equipment.
Check out this video:
http://www.youtube.com/watch?v=5_yE8o6vnMg
Please get back to us if you have any further query or else accept the solution.
