Braun 360° Complete 8985 Electric Shaver Logo
A
Anonymous Posted on Oct 20, 2013
8985 razor cleaner stopped working - Braun 360° Complete 8985 Electric Shaver
Can anyone help with some advice for home razor repair?
After dropping the razor it is very difficult to know what the problem is without examining it. Based on the symptoms you describe, I would guess that the the 'drive unit' is damaged. You will find this part available at shaveroutlet.com. See link below. Scroll down the page for installation help video
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-activator-motor-drive-unit-p-36.html
1helpful
2answers
The screen on my braun shaver has holes and needs replacement can i get new ones for it? its the one that says caution for use only with braun series 549 class 2 power unit www.braun.com it has a trimmer...
Braun 8985 replacement foil and blades is braun series 5 combi 51S foil and cutter replacement pack.
But costomer reviews in amazon.com who take braun series 3 combi 30B foil and cutter replacement pack is fits to Braun 8985 perfectly, very smooth and close shave. Shaves much better than the Braun 51S screens foil.
You consideration
http://www.amazon.com/gp/community-content-search/results/?ie=UTF8&search-alias=community-reviews&tag=best-electric-razors-20&Go.x=0&linkCode=ur2&query=braun%208985&camp=1789&Go.y=0&creative=9325&idx.asin=B001VH6F9G
1helpful
A small steel piece came out betwen the head and body of my 8000 series Braun razor - now the motor runs, but the blade doesn't move - can I fix this (I still have the part)?
The 'drive unit' appears to be broken. You will find this item for model 8985 at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
To replace, you will need to open the shaver body. You will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out
10helpful
Disassemble a braun Clean & renew razor cleaner
To open model 8985 you will first need to gently pry off the 'cap' on the bottom that surrounds the hole where the cord plugs in. Once removed the side grips will pull off revealing 4 screws. Remove screws to take off back cover and access insides. Inner parts simply lift out.
If replacement parts are required, you will find all components for this model at shaveroutlet.com
2answers
New head
Hello Brian, You can give the folks at www.electricshaver.com a try. They typically stock all the replacement and repair parts for most brands of electric shavers.
Here's a link to their site where you'll find part #5646768 for about $38 for a new set of the cutter head and foil (screen). It's always best to replace BOTH the foil and cutter block (head) at the same time, as any mircro burrs or nicks in the cutter blades will quickly ruin any new foil screen.
http://www.electricshaverstore.com/get_item_5646768_braun-foil-cutter-kit-360-complete-8000-series.htm
As you know, this is the simplest and easiest way to get an electric shaver back to a "like-new" shaving experience.
I hope you find this Very Helpful and best regards!
8985 360 conplete. I got a new charger & cleaner base. Unit chargers and full lights comes on. Cleaning cycle lights does not work or clean. This is third new base i tried. I think truble is razer. I...
the razor is warranted for 2 years if you want to contact Braun for replacement. You can try to tap the razor with the palm of your hand after taking off the shaver top and blades. Sometimes this will help dislodge anything that is keeping the shaver from making good contact inside razor.
Just don't beat it against anything hard.
4answers
Where can i get a cleaning stand for the braun 8985
http://cgi.ebay.com/Braun-8985-Electric-Razor-Comes-with-everything_W0QQitemZ270329232498QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item270329232498&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50
EMPTY!?!?
The "empty" light is for the cleaning solution. It needs to be replaced with a new clean cartridge. There should be a big button on the back of the cleaning unit which opens it up and allows you to replace the cartridge.
4helpful
3answers
360 is saying empty
I just fixed it now .. when the cartridge is inside and full turn the whole bas upside-down for less than a sec .. ( while the power plug is disconnected ).. then try plugging and cleaning again
2helpful
Braun 360 Cleaning base
When you are looking top down into the cleaning base you want to look to the left side of the hole where you put your razor. That is were the solution drains out after your razor is cleaned and there is probably a blockage there. I used a toothpick to clean mine out every once in awhile when gunk would build up there.
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
ZJ Limited
ZJ Limited
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
