Husky washer engine only runs off the primer fuel
hello,remember,it has to create vacuum [suction] to draw fuel in,the very fact you are using the 'primer' proves that it is only a fueling problem,and is simply not 'drawing in fuel on it's own.check that there are no 'crud' build up beyond the needle valve,is the air supply restricted?as no air in, 'NO FUEL'! recheck the list again,you will discover[happily] that you were on the verge of 'cracking it' best of luck, cheers.
