https://www.rackaid.com/.../
cannot-
send-email-how-to-fix-email-
sending...
This likely means SMTP authentication is not enabled. If you get a relay denied error and your password is correct, then SMTP authentications is likely not correct. Often, email users with this issue can receive but cannot send email.
www.gn.apc.org/.../i-am-
rec...
Association for Progressive CommunicationsThe usual symptom is that Thunderbird will try to send for about 20 seconds before giving up with "Sending of message failed. The message could not be sent ...
support.hostgator.com > ... > Email > Email Troubleshooting
If you aren't able to send email, this usually means one thing: your internet provider is blocking you from using anyone's outgoing mail servers but their own. ... so that theycan monitor outgoing email on their network in order to prevent spam.
www.inmotionhosting.com > ... > Email > Email Troubleshooting
Jan 14, 2015 - Outlook 2013, cannot send mail, but can receive mail ... I haven'treceive any mail since yesterday and I can't send mails too... can you help me ...
discussions.apple.com > Support > Apple Support Communities
Apple
Are you trying to print emails, or send and receive them?
If you are trying to print, are you able to print from other programs? If not, then it is an issue with the connection of the printer, which could be many things from a setup error in the computer, to a printer out of ink or turned off. Try shutting everything down, check your connections, then turn your printer on first, then your computer.
If you are trying to send and receive emails, more info is required. What program does it use? Did it used to work? When did it stop? Did something else happen then too, eg electrical storm? Can you still browse the internet? Have you turned your computer off and on again?
Please try to be a little more specific on what it is you are trying to do, then we might be able to help you.
