Question about Philips Magnavox MWD7006 DVD Player
But what if the dvd player is just a plain magnavox dvd player wirhout the recorderback then could Instill hook it up to my emerson flat screen tv?
4 Suggested Answers
6ya staff
SOURCE:
salsaurbana
Luis Rondon
  • 56 Answers
SOURCE: HOW DO I CONNECT MAGNAVOX DVD/ VCR TO VIZIO FLAT SCREEN
Is simply. get the audio/vido cables and look on the back of the TV and connect from the audio video outputs from the combo to the audio video inputs on the tv. remember the colors of the terminals and connect them that matches the red, white (audio) and the yellow (video). Using the remote locate the button "input" or "source", and select video 1 or 2, depending where you connected it.
Posted on Nov 19, 2008
Anonymous
SOURCE: I need the code Magnavox MWD200F DVD Player.
The code for MAGNAVOX MWD200F is 447 (247 partially works). It had been tested in two Philips universal remote controls (CL015 and CL035A).
Greetings
CRENDON
Posted on Jan 19, 2009
Anonymous
SOURCE: hook up of magnavox zv427mg9
I have a magnavox dvd recorder/vcr combo (ZV427MG9A) connected to my Sharp hdtv via hdmi cord, Can anyone tell me simple setup steps to make it record and play on either sides. I have read instruction book over and over and it is still not recording to disc or tapes. I also have Charter Cable connected. Can you tell me what do i need to do to make it work. H-E-L-P!!!!
Posted on Dec 29, 2009
Compatability with magnavox combo dvd and vcr
the back of the vcr/dvd player will have some rca plugs that are red,yellow,white,they will be labeled out putthe yellow is video,the red and white are left and right audio,the back of your tv should have the same thing,it should say input,get a rca cable with plugs on both ends and match the plugs to the colors,if you tv or dvd player,doesnt have these,then you will need to plug your cable box into the dvd player and run a coaxial from the dvd player and tv,use channel 3 or 4 on the dvd player and 3 or 4 on the tv
May 08, 2015 | Magnavox Televison & Video
Is Magnavox DVD player and playstation 2 compatible to insignia tv
sounds like the learning curve hasn't kicked in yet put the tv and the correct input and I'll bet it works
Mar 02, 2015 | Insignia Televison & Video
I just bought an L G DP122 DVD player from WalMart--where I purchased my Emerson flat screen TV--and I CANNOT hook up the DVD player to my TV--the DVD will NOT play. My DVD Player has three (3)...
Make sure tv input is set for the slot you plugged the DVD
into.On the tv remote you will find inputs.Just change for the right one.
Most of the time DVD player is working when TV is on channel 2 or 3 .
Mar 02, 2017 | Emerson Televison & Video
How do i hook up a magnosonic dvd player to my tv...the tv is a flat 27" emerson
Download the user manuals for both devices. It will give you more details.
May 31, 2012 | Televison & Video
Cannot connect DVD/CD player/Magnavox Model#DV200MW8 to Emerson Flat Screen TV Model#LC320EM2 (pdf)
This is true, there is no direct output from the player to that model. You can however get a converter. The easiest path would be A/V to HDMI using a converter box made to make that connection. If you prefer, use a different player to connect to that set.
References:http://www.emersonaudiovideo.com/products/product.php?id=27
http://www.walmart.com/ip/Magnavox-DVD-VCP-Player-DV200MW8/5585221
Mar 24, 2012 | Magnavox Televison & Video
Dvd-no picture
Do you have a flat screen tv?
Jan 03, 2009 | Philips Magnavox DVD/VCR Dual Player
Spencers jumbo remote
The Emerson DVD code work work for Magnovox. (I used 447) I figured this out since I have both DVD player and the one remotes always interfers with the other.
Mar 16, 2008 | Marsh Magnavox MSD124 DVD/CD Player
Dvd/vcr installation
I have a sony regular tv and I have direct tv box. Do I hook up the dvd player to the direct tv box?
Jan 15, 2008 | Philips Magnavox DVD/VCR Dual Player
Need remote codes
http://www.amerimark.com/cgi-bin/amerimark/postkey_find.html?cm_mmc=channel-_-engine-_-media-_-26641&keywords=26641&media=G60710&ci_src=14110944&ci_sku=26641
Can buy a similar unit at Meijer if they are in your area. WalMart probably has them too. The one I got my Dad (from meijer) has a code search function built in.
Dec 12, 2007 | Emerson EWD7004 DVD Player
Philips Magnavox MWD7006 DVD Player Logo
41 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
