SOURCE: not reading Hi8 tapes
Fidus, I am not sure where you are located but the camcorder you're trying to use now is a PAL version of Sony's 8mm camcorder. If the tapes you recorded earlier were recorded in D8 (digital 8) or 8mm/Hi8 format NTSC, they will not play correctly in this unit. The NTSC and PAL formats are different and not compatible. Hope this helps you. Joe Weibel customelectronics.org
SOURCE: Error Message Reconect Power even if power is connected
It sounds like the tape door is out of alignment, causing stress on the tape and the inside mechanical system. Requires a visit to the service shop.
SOURCE: connect Sony Handycam DCR-PC5 Mini DV Digital Camcorder to my Laptop
try to install the cd software of your sony handycam into your laptop..
hope it will help thanks...
SOURCE: Sony Cassette TC-WR535 BELT REPLACEMENT
Can you give me some instructions on how to replace the belts?
THANKS
SOURCE: sony handycam dcr-hc53
I think you are using Windows Vista and facing problem to connect Sony DCR-HC53
Download Update for Picture Motion Browser software at Sony Support.
You need iLINK cable to transfer movie data in to computer. iLINK cable is shown in below picture.
You can have more info HERE about iLINK connectivity if you are running Windows XP in your laptop.
This is usually caused by a defective component in the tape detection circuitry and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
