The fabric softener and bleach will not dispense properly. They're still in the dispenser after the wash. Both liquid and powder detergent dispense ok.
I had the same problem my fabric softener would not dispense.Close shut-off valves and take off the water hoses off the back of the washer and look for blockage on the screen.Mine was plugged up and after cleaning it off it works like new.
This may be due to a faulty solenoid, if the cold water is flowing into the machine under normal use at the start, then check the solenoids as the conditioner has its own, the solenoids are just behind the body where the water pipes fit to the machine, they have 2 wires on each one, and are tested for circuit when machine is unplugged. stat there, hope i have helped
I had the same problem. After cleaning it still would not empty. I changed the water valve and it now works perfectly. Must have been a bad solenoid. If the drawer does not get enough water it will not empty
SOURCE: Whirlpool Duet dispenser problem
this is joyce
You need to call who ever you bought it from and tell them the problem that you are having, I have the same set and I am not having that problem at all. I love my set, just be sure to use the he detergent, or you will have problems that the manufactr will not help with.
thanks,
Dont overload machine the clothes wont smell clean.
joyce
I have the same problem with my Whirlpool Duet washer. Initially the dispenser worked fine but now the fabric softener does not empty at all. I have cleaned the tray and made sure there are no blockages, no help, does anyone have any advice?
