SOURCE: wireless
the wep key is nothing but the securirt key which the router generated it self so we cant find that if u entered one or try this login to ur router and disable all w/l security and configure ue x-box-rate me solved if its help full
SOURCE: Cannot find WEP key on my actiontec modem
if u look at atab which says wireless settings or wireless security ,,u will find the wep key,,best of luck,keep me posted,,giva good rating
SOURCE: WEP key needed for actiontec router
Hi there..
I can understand your problem.
If you want to get the WEP key for actiontec router. Please check this link to get the WEP key. This is screenshot website. The reason why i'm giving this link is, you haven't specified the model number. Go through this link:
http://www.pcwintech.com/node/108
SOURCE: How can I get my WEP key from the router?
You will need to "dial in" to your router. Type 192.168.1.1 into your browser (or obtain this from youir manual). Log in and locate the security section. Note the word used to generate the wep key. Also note what number key you used. Both the security word and the wep key should be visible for you to make a note of for further connections.
SOURCE: I need a WEP code for an Actiontec GT704-WG.
You MUST re-set up the Router again, login with a browser, this time copy paste WEP/WAP code into a notepad document. for use on client (Wii) now after setting up the router, check the SSID, the NAME of the WiFi Connection. Save this in router. Then on the Wii, use that written down key, to put the key into the box, this will allow access.
http://www.actiontec.com/support/product_details.php?pid=40&typ=doc
Get your manual from link above, that will help you set it up.
