Hi Kevin
The easy way is to put a normal off/on switch into the coil ground wire and hide the switch inside of the vehicle in the dash area only know by you.
Then you can shut off the ground of the coil when you don't want to drive it, preventing others from starting it because they do not know where the hidden switch is placed.
I used this method on my 89 Mustang and 94 Dodge Truck.
Bud
thank you very much, i should have said that the engine is EFI and the coil doesn;t appear to be like the conventional coil So i am unsure which wire to use !
I can only guide you on the older models...sorry.
Try resubmitting your request
