SOURCE: Camera won't upload pictures/memory card isn't processing images
I am having the same problem. the program i have got is does not work with the camera. than i tried it on a different computer, which worked perfectly.
SOURCE: Transfer of photos on camera without memory card to memory card
take out the memory card and plug the camera to your computer and it should show that way and save them. hope that helps..
SOURCE: Can photos be transferred from internal memory to sd card
im not sure on yours but on mine there is a option for copying a picture under the menu just go to the pic you want on the externa. memory and go to your menu find copy picture and then it will copy to it
SOURCE: transfering photos from my compuer photo gallery to my camera
Make sure photo files name must be under DSC00001 to DSC99999
connect your camera to computer, click My Computer, Removable Disk, Folder and copy photo files from computer and paste in that folder. If file name is different, camera will not show it in playback though file is in memory stick.
SOURCE: My camera doesn`t read memory card.I tried with 2
On most cameras, once you start to use the internal memory, the camera doesn't want to read a memory card. You need to go into the menu and "reset" the camera. Then, with no card in the camera, go into the menu and "format" the internal memory. Then, insert the card and "format" it. This will erase it so download any pics first.
