Question about Fisher and Paykel Washing Machines
Fault code 49 - Fisher and Paykel Washing Machines
    Champion:
  • 242 Answers
Fault code 49 is a valve fault, but I have found it to often be the motor controller board at fault.
Posted on Nov 11, 2013
6ya staff
SOURCE:
Fault 49 pops up on the screen
If your washer is a Fisher Paykel Top-Load Washer Error Codes = 49 I found this online by typing "Washing Machine Fault 49" into a google search engine...
Error Fault Condition - Water Inlet Valve Fault.
Repair or Check - Unplug the washer from power. Reconnect any non secure wires on the water inlet valve. Replace the wire harness if it is found to be damaged. If the wiring is okay then measure the resistance of the water inlet valves using an ohm meter. If the resistance of each water inlet valve solenoid is not 60 to 62 ohms then replace the complete water inlet valve assembly.
Parts for Replacement - Water Inlet Valve Assembly or Wire Harness.
Mar 09, 2016 | Washing Machines
Intuitive Eco - code 49. What does that mean?
faulty cold water valve, if that doesnt fix it then fault computer board
Feb 27, 2015 | Fisher and Paykel Fisher Paykel Intuitive...
What is the fault when the air bag dash light flashes code 49
It's a common fault on many Fords, usually due to a poor connection in the YELLOW PLASTIC CONNECTOR underneath the passenger seat. Just push it together properly and it should clear the fault. If not, go under the drivers seat and secure all the wires and clips there as well.
Aug 21, 2014 | 2006 Ford Territory 4.0
Fisher paykel aquasmart fault 49
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse, A common thing in Aqua-Smart Machines.
The Smart pump has jammed with lint and caused over current to the board and taken out parts on the board that drive the pump.
Best to get a new/recondition board for your machine.
Apr 20, 2013 | Fisher and Paykel Aquasmart wl80t65c
Fisher paykel aqua smart fault 49
Fisher and paykel toploader washing machine fault 49 water valves all show 60 ohms next step?
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse on it's overload, A common thing in Aqua-Smart Machines i always keep seeing,
Nov 26, 2012 | Fisher and Paykel Washing Machines
Service code 49
HI, Just read your posting and my manual tells me that fault code 49 is a cold water valve fault.Now that means your cold water valve is open circuit or a wire to it is broken or the last thing it could be is your computer board is faulty.Try hot water fill only and see if it fills.Then try cold.do you have an electrical test meter ?if you do, i can guide you throe step by step to find the exact cause.hope this helps please reply for further help.
Jun 03, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fault code 49
code 49 cold inlet valve.not filling properly.
May 30, 2010 | Fisher and Paykel Washing Machines
What is fault code 49
Fault code 49 is cold inlet valve
May 22, 2010 | Fisher and Paykel GWL11 Top Load Washer
Code 49 and Manual Book
Fault 49 usually points to the cold inlet valve. I have come across many with this fault that the valve tests ok and it needs the motor controller replaced.
Jan 06, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Open Questions:
Washing Machines Logo
143 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
