Whirlpool Cabrio & Kenmore Oasis Dryer Error Codes- PF--Power failure
- AF--Restricted air flow
- F01--Primary control failure
- F02--Keypad/User Interface failure
- F22--Exhaust thermistor open
- F23--Exhaust thermistor shorted
- F24--Inlet thermistor open
- F25--Inlet thermistor shorted
- F26--Motor drive system failure
- F28--Moisture sensor open
- F29--Moisture sensor shorted
- F30--Restricted air flow
looks like you have a problem with the touch pad,abutton could be stuck or not responding,you can try unplugging it,get to the computer board and unplug the ribbon from the touch pad,reconnect it and try it,this sometimes resets the touch pad,if it doesn't you'll need to replace the touch pad.
