Do you add freon to your indoor unit or your outdoor unit? I have A new 2 ton first co unit indoors unsure what I have outside. Where does the freon go?
I would highly recommend that you get a friend or hire a pro, to deal with this. You dont just add freon, is it -R22 or the new 410A type? You always charge a system from the outdoor unit! If this is a new outdoor condensor, it will be pre charged for the unit, indoor coil and roughly 15 to 25 foot of line set. But after the brazing is done,,, NEVER SOLDERING! You need to use a Vac-Pump and pull the indoor coil and lineset down to 500 microns, before you open the king valves.
If this outdoor unit was used, then does i match the indoor coil? In sizing and type of refrigerant? Need to reclaim the existig refrigerant, pull a deep vacummn on the whole system and then weigh the charge in, according to the tag on the outdoor unit. You should have a CFC license t work with any type of refrigerant, if someone turned you in, it starts with a $ 10,000.00 fine for a start, You need allof the right type of tools and knowlege, save time and money,,,, get a CFC licensed tech,he will know all of this.
Sincerely,
Paul
