Question about Flowtron LE-900 Leaf-Eater Mulcher
Flowtron Leaf-Eater Mulcher LE-900F
When I turn the unit on, it operates for about ten seconds, then stops and has to be reset. This process continues indefinitely. Not sure what is causing it to trip every time
    Problem Solver:
  • 7 Answers
Shot in the dark here. If the mulcher is tripping and needs to turned off then back on, it's defective and should be replaced. If the circuit breaker in your house panel is tripping, try to use different circuit on a 20 amp circuit breaker. If your using a plug that is controlled by a GFCI receptacle or breaker, move to a different plug. GFCI receptacles tend trip when motor loads are applied. These are my best guesses since I'm not sure what exactly you are reseting.
Posted on May 15, 2009
6ya staff
SOURCE:
I need help on how to resolve my printer; KONICA MINOTA BIZHUB 215 error code C3451
power off machine, wait 10 seconds with the clear/stop button held down turn on the main power , get OK or reset then turn off wait ten seconds then on if code comes back replace the fuser unit the hot part continue to reset can cause fire ruining a perfectly good day
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 10, 2018 | Konica Minolta Office Equipment & Supplies
Panasonic air con - when you turn the air con on it runs for about 3 mins and then the timer light flashes. Air con will not work.
• Once abnormality has occurred during operation, the unit
will stop its operation, and Timer LEDs blink.
• Although Timer LED goes off when power supply is turned
off, if the unit is operated under a breakdown condition, the
LED will light up again.
• In operation after breakdown repair, the Timer LED will no
more blink. The last error code (abnormality) will be stored in
IC memory.
• To make a diagnosis:
1. Timer LED start to blink and the unit automatically
stops the operation.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by
pressing the CHECK button continuously for 5 sec-
onds or without any operation the remote control for
30 seconds.
8. The LED will be off if the unit is turned off or the
RESET button on the main unit is pressed.
When you have the error code, we can work out what to do next.
Mar 27, 2015 | Panasonic Heating & Cooling
Hi I have a panasonic split air conditioner. It turns itself off immediately after turning on, the timer button then flashes and that's all.... I have checked for an error code it is H00. I have also made...
Hi Tania,
Have you gone through this checking sequence.? it's from a Panasonic a/c manual. It could be something as simple as a clogged filter. Once you have rectified the fault, you will probably have to clear the fault code as described at bottom below, before it will condescend to work again.
David
  • Once error occurred during operation, the unit will stop its operation, and Timer LED blinks.
  • Although Timer LED goes off when power supply is turned off, if the unit is operated under a breakdown condition, the LED will ON again.
  • In operation after breakdown repair, the Timer LED will not blink. The last error code (abnormality) will be stored
    in IC memory.
14.2.2 To Make a Diagnosis
  1. 1 Timer LED starts to blink and the unit automatically stops the operation.
  2. 2 Press the CHECK button on the remote control continuously for 5 seconds.
  3. 3 "- -" will be displayed on the remote control display.
    Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
  4. 4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed and signal will be transmit to the main unit.
  5. 5 Each press of the button (? or ?) will increase error code number and transmit error code signal to the main unit.
  6. 6 When the latest abnormality code on the main unit and code
    transmitted from the remote control are matched, Power LED will
    light up for 30 seconds and a "beep" sound (continuously for 4
    seconds) will be heard. If no codes are matched, Power LED will light up for 0.5 seconds and no sound will be heard.
  7. 7 The breakdown diagnosis mode will be canceled unless pressing the CHECK button continuously for 5 seconds or operating the unit for 30 seconds.
  8. 8 The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
14.2.3 To Display Memorized Error Code (Protective Operation)
  1. 1 Turn power on.
  3. 3 "- -" will be displayed on the remote control display. Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
    unit.
  6. 6 When the latest abnormality code on the main unit and code transmitted from the remote control are matched,
    Power LED will light up for 30 seconds and a "beep" sound (continuously for 4 seconds) will be heard. If no
  8. 8 The same diagnosis can be repeated by turning power on again.
14.2.4 To Clear Memorized Error Code after Repair (Protective Operation)
  1. 1 Turn power on (in standby condition).
  2. 2 Press the AUTO button for 5 seconds (a "beep" sound is heard) on the main unit to operate the unit at Forced Cooling Operation Mode.
  3. 3 Press the CHECK button on the remote control for about 1 second with a pointed object to transmit signal to
    main unit. A "beep" sound is heard, and the Error Code is cleared
Dec 10, 2014 | Panasonic Heating & Cooling
How to reset error code c0500 on minolta di183 copier machine
Power off the machine wait ten seconds then power on holding down the stop key button. If the code comes back get a new fuser unit, continue to reset with out new fuser could cause a fire that would ruin a perfectly good day!
Apr 10, 2013 | Minolta DiALTA Di183 Copier
How to put a password in a router
Open your Web browser and type "192.168.0.1" (without quotes) into the address bar.
Press "Enter" on your keyboard to access the router.
A login prompt appears.
Enter your username and password to log into the router.
The router's main menu loads.
Navigate to the Maintenance heading of the Main Menu page.
Select "Set Password."
The "Set Password" menu appears.
Enter the router's old password into the Old Password field.
Type the new password into the New Password field. Verify the new password in the Repeat New Password field.
Click the "Apply" button to apply the change.
or if its the WGR614-V6 model
Push the "Default Reset" button on the back of the Netgear WGR614-V6.
The button is located on the back of the unit, to the left of the external antenna.
You may need to use a pin or the tip of a pencil to access the button.
Continue holding the button in until you see the "Power" indicator on the front of the unit turn off and back on.
This takes approximately ten seconds.
Let go of the button.
The Netgear WGR614-V6 shuts off and turns back on.
Allow several seconds for this process to complete.
Log into the router using the default password by opening a Web browser and navigating to the address "192.168.1.1." Enter the password "password" to log in.
hope this helps
Sep 20, 2012 | NetGear WGR614 Wireless Router
Printer displaying error 5C10 and 5110 unble to print copy and scan
Check for paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.
Double check that your ink tanks are new and seated right too
Also be sure that your scanner is UNLOCKED...
With the machine turned OFF:
Open the document cover, look on the tray where the glass is -- and then look to the LEFT side of the glass and you will see pictures of an opened lock and a closed lock and a little switch...
Make sure the switch is next to the UNLOCKED position.
WAIT 10 seconds and then turn the unit back on.
If you STILL have the error code, try these two types of resets:
To clear the memory:
1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
2. Wait approximately ten seconds and then press the <ON/OFF> button again.
3. Wait until the device has completed its cycling process before submitting another job request.
To do a stop/reset:
To clear error messages displayed on the LCD or if the printer is not functioning as expected, it may be necessary to simultaneously press Stop/Reset and ON/OFF buttons.
1. With the printer powered on, PRESS AND HOLD DOWN the <Stop/Reset> button then press the ON/OFF button.
2. Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.
If none of the above clears it up, you may have to have the machine serviced.. check to see if you are still under warranty.
Mar 04, 2011 | Canon MP830 All-In-One Printer
How do I fix error code 5C10, Alarm light blinks for Canon MP830 All in One InkJet Printer?
try these step
First, make sure there is
no paper jam anywhere in the machine.. look inside, rear, where the
Double check that your ink tanks are seated right too
Also, be sure that your scanner is UNLOCKED...
Open
WAIT 5 seconds or so and then turn the unit back on.
Wait until the device has completed its cycling process before submitting another job request.To do a stop/reset:
Once the printer is powered off, hold down <Stop/Reset> and then press <ON/OFF>.If none of the above clears it up, you may have to have the machine serviced.. check to see if you are still under warranty.
Aug 07, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Trouble turning on, displays no mech mode then goes to cartridges
From HP Tech support:
1. Verify that configuration button (Setup button) was not pressed (it was not pressed)
2. Disconect the power cord from the unit
3. Press and hold configuration button
4. Connect the power cord to the unit
(this way the unit gets out from the "No Mech Mode")
5. Stop pressing configuration button (I waited about 15 seconds)
Doing this, the unit seemed to be reset by an intialization process as the cartridges adjusted. It worked fine for me. Not sure of the purpose for error.
Aug 07, 2009 | HP PSC 1610 All-In-One InkJet Printer
Jaguar XK8 Window Problem
Same thing has happened on mine!
The solution is to reprogram the window limits. You need to sit in the car with doors shut! Turn the key in ignition in position I or II, roll down the window all the way and keep holding the switch for 5 seconds, then roll the window up and again keep the switch pressed for 5 seconds, repeat same steps for other door.
Reprogramming is also described in the owners manual. I don't know how mine became deprogrammed, should only happen if the battery is disconnected!
Mar 19, 2009 | 1998 Jaguar XK8
Flowtron LE-900 Leaf-Eater Mulcher Logo
548 people viewed this question
Top Flowtron Garden Experts
roeb
john h
Marvin
Marvin
Are you a Flowtron Garden Expert? Answer questions, earn points and help others
