Always clean you jet tub as directed by the manual. If you don't have one, than fill tub above the jets, add liquid dishwasher gel (not tabs) with bleach and run through the jets for 20 minutes. Drain, fill with clean water and run two times to clean the tub and jets and then use. Be sure your metal filter is clean of hair and soap debris. This will keep your tub and jets nice and clean. Also recommend using Epsom salts and either essential oil of lavender or eucalyptus to your bath. Both essential oils have antibacterial properties. If you want it simpler, purchase Dr. Teal's lavender soak from the drug store. Happy soaking!
